Old 01-17-2021, 09:46 AM   #21
Tim Ayers
Default Re: 266 versus 276 CI?
Originally Posted by tubman View Post
To be clear, there have been a couple of errors in calculating total displacement in this thread. The engine the O/P is describing (3 3/16"+.030" bore with a 4" stroke) is 260 ci, not 266 ci. The classic hot rod "3/8 X 3/8" flathead (3 3/8" bore and a 4 1/8" stroke) is 296 ci, not 286 ci.
If my math is correct, my engine at 3 3/8" +.030" x 4" is a 292.
Old 01-17-2021, 10:26 AM   #22
KiWinUS
KiWinUS's Avatar
^^^^^^291.39ci.
Old 01-17-2021, 11:19 AM   #23
tubman
tubman's Avatar
I'm with "Ol' Ron" in liking a 258 ci flathead (3 5/16" X 3 3/4"). Three more cubic inches than a 4 inch Merc crank will give you with a stock bore for a lot less money. (Lower piston speeds, too; not that it makes much difference with a flathead.)
Old 01-17-2021, 12:57 PM   #24
frnkeore
frnkeore's Avatar
The term "spindly rods" may have come from someone when looking at a flathead rod
Frank
'35 Ford Model 51
'48 Ford F3
'54 Ford Tudor Mainline
frnkeore is offline   Reply With Quote
Old 01-17-2021, 12:58 PM   #25
Phil Gillespie
Phil Gillespie's Avatar
Above is exactly what I am running in a 46 Merc. Coupe. Just running a single 97 Stromberg carb up a couple sizes on jets and PV and standard NOS heads with 45 thou piston to head clearance.
To date have approx 750 miles on engine since full rebuild. For my street use it suits me well.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 01-17-2021, 07:16 PM   #26
Tim Ayers
Originally Posted by KiWinUS View Post
^^^^^^291.39ci.
Would you help a brother out and let me round up? 292 sounds so much better than 291.
Old 01-17-2021, 07:33 PM   #27
raybee
Originally Posted by Ol' Ron View Post
Back in the day, 3 3/8 was a standard overbore for a hotrod. Along with the 4 1/8 crank, you had a 3/8 x 3/8 engine or 286ci
Back in the day, there were a lot of good blocks around.
raybee is offline   Reply With Quote
