Old 01-08-2021, 10:19 PM   #21
51504bat
51504bat's Avatar
Default Re: What is this truck?
Originally Posted by tubman View Post
Help out a poor uninformed "shoebox" guy. That school bus sure looks like it has "wide-5" wheels. Did Ford continue them past 1939 on trucks? Some of the other examples in this thread don't appear to have them.
3/4 tons still had wide fives in '40
Old 01-08-2021, 10:19 PM   #22
Lanny
Lanny's Avatar
Denny, I had a 1941 3/4 or 1 ton back in 1973 that had wide 5 wheels.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 01-08-2021, 10:23 PM   #23
mercman from oz
mercman from oz's Avatar
tubman, I can't answer your question personally, as these Ford Panel Trucks were never available in Australia. You would have to ask someone in the USA who is more familiar with this model.
However, if you look at this Illustration of the 1940 Ford 3/4 Ton Panel from the original Sales Brochure, it does appear to have the same "wide-five" wheels that the School Bus that is on display in the Early Ford V8 Foundation Museum has?
What do other people think?
Old 01-08-2021, 11:35 PM   #24
Brian
Brian's Avatar
The Ozzie trucks use 38 style doors, whereas the American trucks use the 'jailbar' style doors. Look at the swages..
Old 01-08-2021, 11:47 PM   #25
GB SISSON
GB SISSON's Avatar
3/4 tons used the wide fives, on a 122" wheelbase. Only for a couple years. Never seen one in person. Only thing more oddball would be if it had a 4 cyl tractor engine. So now we have a large, long wheelbase truck with big fender openings and little tires and large interior volume that can't climb a hill. It was short lived for a reason.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 01-08-2021, 11:54 PM   #26
GB SISSON
GB SISSON's Avatar
Originally Posted by expavr View Post
Gary
There was a good restaurant (pre Covid) in downtown Anacortes that I might be able to convince my wife that a 3 hour ride in the Tonner would be fair compensation for any aches and pains that might result from that trek. As an added inducement if the Skagit Valley Tulip Festival happens we can turn both wives loose to look at the posies and you and I can wander around some country roads in our old iron. Looking forward to it.
Les
That would be really fun Les! You may want to take the lead, as this little 120 hp diesel rolls a little coal on the hills. Oh wait, the Skagit Valley is really pretty flat. See you then!
Old 01-09-2021, 01:00 AM   #27
cas3
the wide 5 truck hubs and bells were the basis of the early dirt track cars with a QC rear
Old 01-09-2021, 05:07 AM   #28
mercman from oz
Ford Australia built quite a few of these 1940 Open Cab Pick-ups. Many were used by the Army in World War II.
I saw this survivor many years ago, but it's fate is unknown. I don't know if it has been lost or saved?
Old 01-09-2021, 08:27 AM   #29
1952henry
1952henry's Avatar
Would look even better with the Marmon-Herrington underpinnings.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 01-09-2021, 09:04 AM   #30
fordyford
1940 & 1941 Trucks came in 4 "sizes" look at the wheels.
Small pickup looked like a standard car, 112" wheel base 16" 5 on 5 1/2" wheel hub caps same as cars.
3/4 ton looked like the ones in these pictures, 122" W.B. 16" wide 5 wheels & hub caps.
Tonner has same look, 122" W.B. 17" split rims and hub caps specific to them.
1 1/2 ton same look Various W.B. 20" split rims, no hubcaps, dual rear wheels.
The big difference in all of these is size of the brakes to match weight rating.
fordyford is offline   Reply With Quote
Old 01-09-2021, 01:53 PM   #31
expavr
expavr's Avatar
"Tonner has same look, 122" W.B. 17" split rims and hub caps specific to them."
To clarify a misconception the 1940 17" Tonner Rims used a Continuous Locking Ring to hold the tire to the rim as opposed to the Split Rim type.
expavr is offline   Reply With Quote
Old 01-09-2021, 03:43 PM   #32
51504bat
51504bat's Avatar
Never knew the actual term for the one piece ring type wheels. Always referred to any 2 piece rim as a split rim (with the exception of widow makers) Either way they are both a PITA to mount/dismount. IMO. Back in the mid '70's I worked with an old guy (he remembered when a lube job included treating the rubber coating on the running boards) who showed me how to mount/dismount them. Even with the correct tire tools the shop had and his assistance I never was able to change a tire as easily as he could and he had me by 40 years or more.
Old 01-09-2021, 03:44 PM   #33
mercman from oz
Here is a picture of a restored Australian 1940 Ford Open Cab Pickup, similar to the one that I added in Post 28.
This one is from down south in Victoria.
Old 01-09-2021, 03:53 PM   #34
MGG
MGG's Avatar
Here are pictures of my friends 1940 Ford Truck. You can see the V8 pressings on the Hood which denotes that it is a 1940 model. Very nice.
Did the wing windows come on this truck or are they an aftermarket add, or another Australia feature?
MGG is offline   Reply With Quote
Old 01-09-2021, 04:41 PM   #35
mercman from oz
To answer MGG's question:- This illustration of an Australian 1940 Ford Heavy Duty Truck showing Quarter Windows - is from the original Australian Ford Truck Sales Brochure.
Old 01-09-2021, 05:10 PM   #36
gtrhotrod
gtrhotrod's Avatar
1940 for sure.
gtrhotrod is offline   Reply With Quote
Old 01-09-2021, 06:18 PM   #37
mercman from oz
Here are two pictures of Australian 1940 Ford Vans which are illustrated in a Booklet on 1940 Fords published by Ford Australia. Notice that these Vans also have Quarter Windows. Also notice the different full length body moldings that have three strips, which is different to the American body. Also notice that the 15-18 cwt unit has what appears to be Wide Five Wheels.
Old 01-09-2021, 06:29 PM   #38
expavr
expavr's Avatar
Did the 1940 Australian Big Trucks have a cowl vent? I can’t tell from your photos. That might explain the use of 1/4 windows on trucks made in Australia.
Old 01-09-2021, 06:42 PM   #39
mercman from oz
Australia 1941 Ford Open Cab Pickup. Notice that it does not have V8 Pressings on the sides of the Hood, also it has wide trim on the Hood, thereby making it a 1941 model.
Old 01-09-2021, 06:48 PM   #40
41panelmark
41panelmark's Avatar
Originally Posted by flatford8 View Post
I like seeing pics of these trucks.....I took this at the Coles Transportation Museum in Hamden, ME.........Mark
Now that Coles Transportation Museum is a rare bird for sure...
41panelmark is offline   Reply With Quote
