Old 10-04-2020, 07:42 PM   #1
Denali
Default Extreme front end wobble
What causes extreme front end wobble when the brakes are applied?
Mark in Fairbanks Alaska
Denali is offline   Reply With Quote
Old 10-04-2020, 07:50 PM   #2
Joop
Joop's Avatar
Default Re: Extreme front end wobble
Read the Front Wheel Wobble post from JLpete98 a little farther below
Full of good info on your problem.
Joop is offline   Reply With Quote
Old 10-04-2020, 07:52 PM   #3
Harpkatt
Harpkatt's Avatar
Many things could be the cause I would bet kingpin bushings.
But Could be loose lugs, loose drums, misaligned wheels, Loose Spring.
Harpkatt is offline   Reply With Quote
Old 10-04-2020, 08:46 PM   #4
1930-Pickup
Yes, I agree.
I had one a few years ago due to a worn steering box sector shaft bushing.
Once I fixed that, all was well.
Now the 'Death Wobble" (as its known) has returned.
No matter though, I'm was planning a complete front end rebuild soon anyway.
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!"
1930-Pickup is offline   Reply With Quote
Old 10-05-2020, 08:47 AM   #5
Terry, NJ
Terry, NJ's Avatar
This laughingly called "Death Wobble"! Once you've experienced it you will agree! There can be many causes, such as Wheel bearings, king pins, spring Perch bushings, control arm balls out of round, poor alignment, poorly adjusted brakes, and steering box issues. Start by jacking up the front end and shaking the wheels. If you find looseness, do whatever it takes to tighten it. Vertical looseness is king pins (bushings) horizontal shaking/looseness is wheel bearings or steering linkage. This must be observed while someone does the shaking. Ball Diameter on thermos is 1.000, allowable out of round is .980, or 1.000 minus .020. I tolerate 1" of play in the steering wheel, but specs call for zero. Terry
Old 10-05-2020, 09:53 AM   #6
Purdy Swoft
Purdy Swoft's Avatar
Loose king pins never caused death wobble on any of mine . Improper toe in adjustment has always been the cause for mine !!! Toe in adjustment sgould be 1/16fh .
Old 10-05-2020, 11:09 AM   #7
Purdy Swoft
Any other looseness in the front end will also contribute to shimmy after the shimmy begins .
