Old 09-29-2020, 01:29 PM   #1
41panelmark
41panelmark's Avatar
Default dimmer switch 40-41
Arrrgh, I have tried 2 different aftermarket dimmer switches, each seem to not work or fail after a short amount of use. Anyone had good luck with one that they would recommend?
thanks in advance.
41panelmark is offline   Reply With Quote
Old 09-29-2020, 02:25 PM   #2
19Fordy
19Fordy's Avatar
Default Re: dimmer switch 40-41
If you mean the head light dimmer switch this one looks promising as it was made back in the day as a replacement.
https://www.ebay.com/itm/1938-1947-F...UAAOSwHMJYCVyZ
Plus, there are a few for sale in the Swap Section. Just type in dimmer switch.
Old 09-29-2020, 03:16 PM   #3
Kube
Kube's Avatar
Or this one on eBay a lot cheaper...
Item ID: 124357131864
Old 09-29-2020, 07:07 PM   #4
Jack E/NJ
Jack E/NJ's Avatar
Go here instead. Jack E/NJ
Old 09-30-2020, 08:23 AM   #5
1931 flamingo
1931 flamingo's Avatar
I believe in my 40 the switch is in the correct position BUT there's no way I can get my 10 1/2's on to it..................
Paul in CT
Old 09-30-2020, 08:45 AM   #6
19Fordy
19Fordy's Avatar
Paul, What do you mean by when you say there's "no way I can get my 10 1/2's on to it.................."?
Old 09-30-2020, 09:56 AM   #7
Automotive Stud
Automotive Stud's Avatar
His foot is too big to fit between the clutch and the kick panel.
Automotive Stud is offline   Reply With Quote
Old 09-30-2020, 11:07 AM   #8
19Fordy
19Fordy's Avatar
OK, now I get it. Thanks.
Old 10-02-2020, 09:58 AM   #9
41panelmark
Thank you for your help guys. Hopefully this solves the problem once and for all.
Old 10-02-2020, 01:13 PM   #10
drolston
drolston's Avatar
For the record regarding location of the dimmer switch hole:
The dimmer switch on my early model year '41 is lower on the floorboard; slightly below the clutch pedal hole. When I bought a replacement floorboard advertised to fit '41 to '48, the unit I received had the dimmer hole much higher up on the floorboard. I recall that from the '48 I owned 60 years ago as being correct position for that car. The wiring for the dimmer on my '41 would not reach far enough, so I cut a hole lower in the floorboard. That location is easier to reach but also subject to inadvertent activation.
