08-31-2020, 06:01 PM | #1 |
Helmet distributor 12 volt options?
Is there a part available for the Helmet distributor that is 12 volt instead of 6 but it still looks like the old style coil?(not the later coils used in the 60's cars and trucks).
thanks in advance guys. |
08-31-2020, 06:03 PM | #2 |
Re: Helmet distributor 12 volt options?
Skip Haney can rebuild your original coil to negative ground
Sent from my iPhone using Tapatalk |
08-31-2020, 06:08 PM | #3 |
Thanks, I will check with him on the 12 volt thing also.
08-31-2020, 06:09 PM | #4 |
He uses the same coil for 12 and 6 the only difference is the polarity and resistor used
08-31-2020, 06:12 PM | #5 |
Thanks, do you have his contact information handy?
08-31-2020, 08:47 PM | #6 |
09-01-2020, 01:17 AM | #7 |
09-02-2020, 09:35 AM | #8 |
