05-25-2020, 05:42 PM | #1 |
KR Wilson Groover
Hi All
i have a KR Wilson Brearing Grooving tool. It is missing the cutter. i was wondering if anyone could give me any details on the cutter. Thanks Rob |
05-25-2020, 07:06 PM | #2 |
Re: KR Wilson Groover
does this help any,
The ring with the slot is for setting the cutter to maximum depth |
05-25-2020, 07:45 PM | #3 |
You make your own cutter out of some 1/4 high speed steel stock. Most machine tool shop sell. It will need to be shaped using a grinder to match the groove needed.
05-27-2020, 08:02 PM | #4 |
thanks 1930 Coupe.
would you have a close up picture of the cutter. Regards Rob |
05-27-2020, 09:02 PM | #5 |
It is a very unusual cutter, it just pushes in and must be free to rotate. A spring clip keeps it from falling out.
05-27-2020, 10:54 PM | #6 |
05-28-2020, 12:27 AM | #7 |
Thankyou 1930 Coupe
Seeing the cutter now makes sense. As i have the jigs i may as well use them. the guide channel on mine has been damaged so i will need to repair them first. i assume someone tried to put a standard cutter in it with out the front guide and it took a chunk out of the guide. i will make a drawing of the cutter for future reference. thanks again Rob |
05-28-2020, 09:30 AM | #8 |
Interesting because my original cutters did not look like that. I will go down and take a picture when I have a moment.
05-28-2020, 12:46 PM | #9 |
Thanks Terry.
Easily made made from high speed round stock, probably 5/16? Notice the relief angles on top and sides. Machinist call them form tools and sharpen using a abrasive honing stone. |
05-28-2020, 05:22 PM | #10 |
The material that is being cut has to go somewhere. It usually tries to curl up. The one pictured in post #5 doesn't seem to allow for that. I think someone was looking for a way to control the cut somehow but I'm not sure how it would work or if it would even work at all.
05-28-2020, 06:01 PM | #11 | |
I have used it many times and it works great and makes a very nice grove. Are you saying that I need to stop using it and put it in the trash |
05-29-2020, 10:05 AM | #12 |
Without going to look at it it im pretty sure mine has a cemented carbide tip. Maybe thats why the odd shape on the one shown
05-29-2020, 10:10 AM | #13 | |
For "ripping" thru soft metal at a snail's pace, what would the advantage of carbide be? I would think it would have been an unnecessary waste of money. Am I missing something?? |
05-29-2020, 10:56 AM | #14 | |
If you think I inferred your last statement above in my last statement on post #10 then you are reading in something that isn't there. |
05-29-2020, 11:40 AM | #15 |
I am happy and OK, just did not want other people to get confused.
If you tried to hog it through with one heavy cut, then it might do like you said. I take 3 or 4 light cuts and it works great. |
05-29-2020, 04:43 PM | #16 |
B79A4A35-2674-4B40-B473-B7BE804C80E3.jpeg. Def a brazed on tip and another broken one i found. Figured some tried to salvage a broken on by grinding it like that. Are they home made? Possibly
