05-15-2021, 04:59 PM | #1 |
28/29 - 30/31 crankshaft difference??
Is there a difference in the 28/29 crankshaft and the 30/31 crankshaft?
28/29 weaker from rod journal to rod journal 30/31 stronger, beefer build in that area?? |
05-17-2021, 06:43 AM | #2 |
Re: 28/29 - 30/31 crankshaft difference??
Other than the very early 1928 beavertail crankshaft I'm not aware of any difference in the later ones
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
05-17-2021, 10:31 PM | #3 |
Thank you for your input
05-17-2021, 07:57 AM | #4 |
Beavertail lighter...spools up quicker
05-18-2021, 11:12 AM | #5 |
While the crankshaft being a bit lighter has some affect in inertia, the weight of the flywheel has much more of an affect. With forged steel, the difference in weight is not all that much. I think Ford made the throws a bit heavier to help reduce flex. The early multi-disc clutch & flywheel was lighter than the later single disc type clutch & flywheel,
There were two changes that I'm aware of in the more taper shaped crank throws (beaver tail) of the 1928 shafts but they were in size (diameter) of the round or cheek portion of the throws. Some are smaller ID than others or so I've been told. The difference in weight between the thick throw types and the tapered throw types is less than a pound according to Vince's information on the Ford Garage site. The counter-weighted cranks are the heavy ones but the counterweights take out some of the natural flex of the early types and that will make the center main last longer. Ford parts were constantly being changed or improved in subtle ways as time went by. Improvements were generally made for reliability of the entire engine assembly. |
05-19-2021, 10:38 PM | #6 |
Thanks for the input |
05-19-2021, 10:50 PM | #7 |
I think what Rotor is leading up to are the Model "B" cranks and later.
The "A" was a smaller journal/rod throw then the "B". Not that some have modified "B" and "C" cranks to fit into the "A" block John
As Carroll Smith wrote; All Failures are Human in Origin. |
05-20-2021, 04:11 PM | #8 | |
Sent from my SM-G973U using Tapatalk
1929 Briggs Fordor 165B 1930 Deluxe Coupe 1966 Mustang 2015 Ford Focus ST |
05-20-2021, 12:33 PM | #9 |
Some folks add counterweights to the model A crankshafts. The early B engines didn't have the counterweights yet so they vary too. There were different forms of counterweights in the B era as well.
Don't be afraid to use any of the model A crankshafts. Many have pounded pretty hard on the early types and reported little problems with them. Most folks that run them hard are fully aware that something can happen to any of them. The center main is likely going to wear out before the others just because the design only had the one central main journal. Flathead V8s can have the same problems. The early connecting rods that has the X-shape probably should be retired. I've heard of problems with them. Last edited by rotorwrench; 05-20-2021 at 12:49 PM. |
05-20-2021, 05:34 PM | #10 |
Rotor is correct in that people, other than Ford added counterweights to the "A" cranks.
Please correct me if this is in-accurate. The "A" crank was undersize on the mains known early in the program, but still produced. See Hicks' recounts about the "A". The "B" crank first produced was without counter weights, very soon after the "BB" added counterweights appeared. Then the "C" version with forged in counterweights. There are a couple ways to put the "B" crank in the "A" block, I have done the mains to a larger than "A" and used late model bearings. This is stronger to help accommodate cross drilling for full pressure oiling with "B" rods. All good, John
