Old 09-14-2017, 11:01 AM   #21
tubman
tubman's Avatar
Default Re: stock dist with jr. isky cam
Originally Posted by 40 Deluxe View Post
Seems like I remember there being dual point conversion kits for these load-O-Matics back in the '50's or '60's.
Yep! The first piece of "Speed Equipment" I ever bought back in 1958 for my first '51 Ford. Made by Mallory. It came with the brass "trash can" condenser so there was actually something to show your friends when you opened the hood.
Old 09-14-2017, 05:53 PM   #22
JT FORD
JT FORD's Avatar
You can buy them often on e-pay. Its just a new plate with two set of points. The big condenser was mounted on the motor outside the dist. They worked just fine, better than one set. I have seen this age old argument on forums for years that the loadamatic wouldn't work with a cam and dual carbs. Most of the arguments were made by people that has never done it before, just read other opinions.
JT FORD is offline   Reply With Quote
Old 09-14-2017, 06:45 PM   #23
JSeery
JSeery's Avatar
Thanks for the input, never heard of one, but then was never interested in one! I have ran a lot of Mallory full mechanical dual points and had good success with them.
Old 09-15-2017, 06:21 AM   #24
41LjH
41LjH's Avatar
All things are relevant. If you are cammin' the engine consider a mechanical advance distributor. Gas mileage will suffer, but drive-ability should be fine.
3 pedals, 3 gears, no valve-covers..
Now THAT is a hot rod !!
https://www.youtube.com/watch?v=ZmwwB34vxJE
41LjH is offline   Reply With Quote
Old 09-15-2017, 12:53 PM   #25
rotorwrench
rotorwrench's Avatar
That's why the later centrifugal plus vacuum works so well. Centrifugal for quick response and vacuum for load variation over the whole range. This just works better for both performance and gas mileage.
Old 09-15-2017, 03:51 PM   #26
Ol' Ron
Ol' Ron's Avatar
Lets look at dual points. Just how do they Affect timing? Just think about this.
Old 09-16-2017, 02:20 PM   #27
Ol' Ron
Ol' Ron's Avatar
BTT I think this is important, sometimes miss understood
