Old 11-28-2020, 06:40 PM   #1
Tudor36
Default 1949 Flathead Ford F1 3 spd topload transmission rebuilt
City: hedgesville
State: West Virginia
Price: 1800.00
Completely rebuilt 1949 Ford F1 3 speed topload (shift) transmission. Open driveshaft. New cluster, 2nd, low /reverse slider and reverse idler gears, main drive shaft, reverse and cluster shafts, bearings, thrust washers, synchronizers, clutch shaft, shaft bushings and shift lever detent ball and springs. Only main component that was reused was the good output shaft. Had a good case was cooked and epoxy primered. No wear inside case wear thrust washers go. Was planning on using in my truck until I found that the crank for my engine was cracked. So using a different engine in my truck. Was told that these transmissions can be used when converting older Fords to open driveshaft. 2nd from last photo is trans disassembled with old parts and last photo is new parts installed. Have over $1200 in parts alone.
Can ship freight buyers expense
Tudor36 is offline   Reply With Quote
Old 12-02-2020, 07:32 AM   #2
Tudor36
Default Re: 1949 Flathead Ford F1 3 spd topload transmission rebuilt
Btt
Old 12-05-2020, 03:52 PM   #3
Tudor36
New price $1900
Old 12-13-2020, 09:13 AM   #4
Tudor36
Btt
Old 12-17-2020, 07:18 AM   #5
Tudor36
Btt
Old 12-21-2020, 05:44 PM   #6
Tudor36
$1850 btt
Old 12-30-2020, 08:00 AM   #7
Tudor36
Btt
Old 01-01-2021, 09:25 AM   #8
Tudor36
New price $1800.
Old 01-15-2021, 12:38 PM   #9
Tudor36
Btt
Old 01-18-2021, 06:18 PM   #10
Tudor36
New price $1750
Old 02-02-2021, 08:18 AM   #11
Tudor36
Btt
Old 02-06-2021, 09:05 AM   #12
Tudor36
New price $1700. Also have bellhousing and starter plate available. Can call 304 754 3073 between 8am-7pm EST Mon-Sat
Old 02-11-2021, 05:06 PM   #13
Tudor36
Btt
Old 02-15-2021, 02:50 PM   #14
Tudor36
New price $1650. Can't pay someone to rebuild it plus the $1200 in parts for this .Can ship freight buyer's expense.
Old 02-23-2021, 08:59 PM   #15
Tudor36
Sold!
