Old 05-18-2020, 11:12 AM   #1
NH David
Default Arcing Brake Shoes
Looking for someone to arc my new brake shoes in Southern NH or Mass.
Any help would be appreciated.
Thanks
NH David is offline   Reply With Quote
Old 05-18-2020, 11:20 AM   #2
Charlie Stephens
Default Re: Arcing Brake Shoes
Be sure to also ask at your local Model A and Early V8 Ford Clubs. I ended up sending mine back to the manufacturer.
Charlie Stephens
Old 05-18-2020, 09:47 PM   #3
1930artdeco
1930artdeco's Avatar
Try a truck brake shop. They still arch shoes and might be able to do yours.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 05-19-2020, 07:41 AM   #4
1931 flamingo
1931 flamingo's Avatar
Location, location, location. Where are you?? There may be someone down the street from you who could do it.
I don't understand why people are reluctant to post their location??
Paul in CT
Old 05-19-2020, 07:50 AM   #5
David R.
I did mine for my AA the redneck way. I used a bench belt sander. Trial and error. Took small amounts, try fit in drum, fielders gauge, try fit, repeat...
David R. is offline   Reply With Quote
Old 05-19-2020, 07:55 AM   #6
ryanheacox
ryanheacox's Avatar
That's the way I did mine. I imagine after a few hard stops whatever small high spots there are will be gone.
Old 05-19-2020, 08:26 PM   #7
bobbader
David, Check your PM (Private Message folder).
Bob Bader
bobbader is offline   Reply With Quote
Old 05-19-2020, 08:58 PM   #8
billy myers
i can do it for u dave i am in conn by bradley air port 10.00 per shoe 8608835290
billy myers is offline   Reply With Quote
Old 05-20-2020, 06:49 AM   #9
Patrick L.
Patrick L.'s Avatar
You could line the drum with sand paper, insert shoe and carefully rub.
Old 05-20-2020, 06:52 AM   #10
ryanheacox
ryanheacox's Avatar
I saw someone posted that here once and others said it wouldn't work perfectly because you are arcing it to the radius of the drum minus the thickness of the sandpaper.
It still seems like a clever idea to me. I don't think the thickness of the sandpaper would make a huge difference.
Old 05-20-2020, 09:17 AM   #11
larry harding
i have a friend(in his eighties) here that has worked on a's most of his life. he has a way
to arc the shoes in a press to make them fit the drum. in fact he gave me his old brake shoe grinder, never uses it. just bends the shoes til they fit the drum radius.
larry harding is offline   Reply With Quote
Old 05-20-2020, 03:01 PM   #12
NH David
Paul in CT
I'm in Southern NH.
Old 05-20-2020, 05:47 PM   #13
Patrick L.
Patrick L.'s Avatar
Exactly right.
Old 05-20-2020, 05:48 PM   #14
Patrick L.
Patrick L.'s Avatar
Many years ago when Macs was still Lockport they said thats how they did them. Stuck the shoe in a press and 'warped' it.
Old 05-22-2020, 09:39 PM   #15
NH David
Thanks Billy.
I'm in the process of relining my shoes. I'll let you know how I make out.
Dave
