Old 03-05-2014, 11:54 AM   #1
Shadetree
Shadetree's Avatar
Default This Site Is Awesome!
We all take for granted the features designed into this site. But if you are like me you hardly scratch the surface of all the built in features. Thanks to Ryan and his well designed site we enjoy the day to day communications with fellow Ford enthusiasts.
Originally Posted by Terry,OH View Post
Shadetree: The transmission case and internals will fit the 35 without problems. Have to change the clutch release lever on the side of the transmission to the 35 lever, and use the 35 rear bearing retainer (motor mount). The 35 transmission cover (floor pan) will have to be modified slightly to accept the later transmission top, which has to be used due to the 3" shift fork, the shifter has to be changed to the 36 or later because the rod going into the top of the transmission for 35 is different and will not work with the double detent top.
I got to thinking transmissions and recalled a recent thread discussing my 1941 pickup version. Someone replied that I could use the internals and top from the `41 in my `35 transmission. I could not remember who posted a response to my request or what thread it was on. I simply searched for 1941 transmission and there it was!
I took Terry Of Ohio’s comment too lightly. Should I have reason to remove the transmission or engine I would do just as Terry suggested, swap the internals. This way I could keep the original case that came new in my car as it matches the numbers on the frame.
Thank you Terry and Ryan too!
Bud Reynolds
Son, you will never blow an engine up in high gear.
Shadetree is offline   Reply With Quote
Old 03-05-2014, 08:39 PM   #2
RKS.PA
RKS.PA's Avatar
Default Re: This Site Is Awesome!
Bud, couldn't agree with you more!! If you can't find the answer here, it probably doesn't exist....the knowledge is awesome too...an unbelievable resource!!
Dick.
RKS.PA is offline   Reply With Quote
Old 03-05-2014, 08:42 PM   #3
TonyM
TonyM's Avatar
Yep, Love this forum. Look in on it every single day. Lots of smart guys here.
TonyM is offline   Reply With Quote
Old 03-05-2014, 10:42 PM   #4
pineapple
pineapple's Avatar
Agreed, Thanks to all, I've learned so much here.
pineapple is offline   Reply With Quote
Old 03-06-2014, 02:54 AM   #5
hardtimes
hardtimes's Avatar
Hey Bud,
Agree also that Ryan is a blessing on us in our hobby. Thanks to you for pointing Ryan up for the good that he does ! And, he IS a big car buff !
hardtimes is offline   Reply With Quote
Old 03-06-2014, 07:50 AM   #6
Barry-ct
Barry-ct's Avatar
None better than this site!
Barry
50 F-1
Barry-ct is offline   Reply With Quote
Old 03-06-2014, 08:08 AM   #7
sortkaffekop
sortkaffekop's Avatar
Thump up!! (Though I only got an French with a small 66 engine)
/Christian
sortkaffekop is offline   Reply With Quote
