Old 11-28-2020, 05:31 PM   #1
JOHNCL
Default A and AA flywheel castings
I have several flywheel cover castings for Model As and they have the side mount provisions for the frame mounts. I also have what I think is an AA flywheel cover and bell housing, with a socket on the bottom for the wishbone ball and the flange for a truck 4 speed transmission. but it does not seem to have side mount provisions like those on a car's casting. Is it supposed to bolt to the car-type casting, or what?
JOHNCL is offline   Reply With Quote
Old 11-28-2020, 05:34 PM   #2
jerrytocci
Default Re: A and AA flywheel castings
could be tractor
jerrytocci is offline   Reply With Quote
Old 11-28-2020, 07:00 PM   #3
Bob C
The AA uses the same flywheel housing as the A, the picture is an AA clutch housing.
Old 11-28-2020, 09:29 PM   #4
40 Deluxe
Originally Posted by jerrytocci View Post
could be tractor
No Ford tractor ever used a Model A engine or bell housing. There were some aftermarket tractors such as the Worthington mowers that used regular Model A stuff and industrial/agricultural power units based on the A but no Ford factory built tractors based on the A.
Old 11-29-2020, 02:07 AM   #5
Richard in Anaheim CA
Richard in Anaheim CA's Avatar
I have always called that housing the bell housing which is bolted to the clutch or flywheel housing which has the mounting attachments to the frame.
Richard in Anaheim CA is offline   Reply With Quote
Old 11-29-2020, 10:44 AM   #6
Purdy Swoft
Purdy Swoft's Avatar
Right on , I agree .
Old 11-29-2020, 11:34 AM   #7
SteveB31
SteveB31's Avatar
It is likely for later then Model A. The 4 speed transmission was used for 30 years, but had different clutch housings for each year it was used. If you posted a photo, I could likely identity it for you.
SteveB31 is offline   Reply With Quote
Old 11-29-2020, 11:52 AM   #8
Bob C
I've always called it a bell housing also but Ford called it a clutch housing 7501.
Old 11-29-2020, 07:12 PM   #9
JOHNCL
Thank you all for your responses. I will verify in the next few days.
