Old 09-18-2020, 12:51 PM   #1
2935ford
2935ford's Avatar
Default Running engine with no dip stick?
Oil going to blow out the dip stick hole?
2935ford is offline   Reply With Quote
Old 09-18-2020, 01:14 PM   #2
ryanheacox
ryanheacox's Avatar
Default Re: Running engine with no dip stick?
Not a ton but it will. For whatever reason, I once put the dipstick down in the side pan instead of back in its hole and then drove 20 miles. Didn't lose that much oil, not enough to be dangerous at all. I did lose that dipstick though...
Old 09-18-2020, 01:19 PM   #3
2935ford
2935ford's Avatar
Thanks ryanheacox
Old 09-18-2020, 01:40 PM   #4
rfitzpatrick
'dip-stick' we had a troop in out squad called that. Always answered too
rfitzpatrick is offline   Reply With Quote
Old 09-18-2020, 01:50 PM   #5
Redbird
Redbird's Avatar
Yes it will. I lost one one time and made one out of a twig and a straw, until I could get another.
Redbird is offline   Reply With Quote
Old 09-18-2020, 02:56 PM   #6
McMimmcs
McMimmcs's Avatar
Sorry I don’t agree. I think you’ll have a big mess to clean up, I know I did !
Old 09-18-2020, 03:02 PM   #7
Big hammer
I looked at a new owners pu and he had oil on the firewall, steering column, etc, what a mess. I asked him for permission to install the dip stick properly he said yes and thanked me.
get a bigger hammer tap done
Old 09-18-2020, 03:59 PM   #8
2935ford
2935ford's Avatar
I did not know there was a proper way they go in?
Old 09-18-2020, 04:53 PM   #9
ryanheacox
ryanheacox's Avatar
I’m guessing he didn’t have it in all the way?
Old 09-18-2020, 04:55 PM   #10
ryanheacox
ryanheacox's Avatar
Mess, absolutely. Big loss, no. Doesn’t take a lot coming out to make a big mess. It’s like glitter
Old 09-18-2020, 05:16 PM   #11
shew01
shew01's Avatar
Yup. You need to fully insert the dipstick into the hole. Some dipsticks are a little sprung. You may need to squeeze the round area together so that both “legs” of the dipstick will go into the hole.
Old 09-18-2020, 05:50 PM   #12
2935ford
2935ford's Avatar
Oh, I understand.
Mine just drops in.
Old 09-18-2020, 06:15 PM   #13
Y-Blockhead
Y-Blockhead's Avatar
Oh, I understand.
Mine just drops in.
I have found the the repros (from Vintique of course) are a little small in diameter and fit a bit loose. On those I spread the legs a little so it holds tight and put a small 'o' ring on it.
File Type: jpg transport-car-stupid-auto_care-car-spare-abr1307_low.jpg (70.3 KB, 88 views)
Old 09-18-2020, 08:32 PM   #14
Sunnybrook Farm
Sunnybrook Farm's Avatar
I got a late 28 motor off of craigslist, covered in grease and road dirt, I only bought it because of the price and all the dirt kind of told me that nobody had messed with it in the last 70 years or so. Anyway it didn't have a dip stick and had plugged the hole it's self with oil and road dirt, it is a self healing type of thing if you run them long enough. Other holes were filled in the same manner. I took it apart and found the timing gear was off one tooth so whoever ran it probably wasn't real happy after the last guy worked on it. Still has a good multi disk so I am going to use it for a while in my off road truck.
Sunnybrook Farm is offline   Reply With Quote
Old 09-18-2020, 10:23 PM   #15
PalAl
PalAl's Avatar
Well I didn't know.......... so I tried it. My engine spits out oil and makes a mess, so for me the stick stays in the proper hole.
PalAl is offline   Reply With Quote
Old 09-19-2020, 07:17 AM   #16
fundytides
fundytides's Avatar
Not a Model T but years ago the crankcase breather in my sons Chevy II got plugged up and crankcase pressure blew the dipstick out along with considerable oil. Quite a mess.
fundytides is offline   Reply With Quote
Old 09-19-2020, 07:18 AM   #17
fundytides
fundytides's Avatar
Sorry, Model A
Old 09-19-2020, 09:22 AM   #18
Jack Shaft
Pump gravity and splash oil system.its like a monsoon in the crankcase,the connecting rod and crankshaft throw passes through a tray of oil each rotation with a little 'cup' or dipper picking up oil to lube the rod bearing,the rest splashes up against the cam and lifters,simple yet effective.
Old 09-19-2020, 12:38 PM   #19
McMimmcs
McMimmcs's Avatar
You have everyone laughing! Why in the world would u try it ! Unbelievable.
Old 09-19-2020, 03:27 PM   #20
2935ford
2935ford's Avatar
Well, thank you for the experiment.....now we know!
