Old 11-28-2020, 09:11 PM   #1
charlesea
charlesea's Avatar
Default Two tooth setting in a 28/29
Can a 2 tooth steering box be used in a 28/29 A Model with out modeification? I know the shaft will have to resized if this would be ok to do.
charlesea is offline   Reply With Quote
Old 11-28-2020, 10:56 PM   #2
Mike Peters
Mike Peters's Avatar
Default Re: Two tooth setting in a 28/29
The two tooth Gemmer steering sector was used interchangeably from Feb. 1929 along with the 7 tooth sector to the end of 1929. It was 1 inch shorter than the 30-31 steering column. For 1929, the steering shaft for the two tooth Gemmer sector was 43" long. the 30-31 steering was 44" long.
So yes, the two tooth sector can be used without modification if it is the shorter 29 version.
Mike Peters is offline   Reply With Quote
Old 11-28-2020, 11:45 PM   #3
Bill G
Bill G's Avatar
Was there an early versus a later version of the Gemmer box?
Old 11-29-2020, 07:31 AM   #4
Mike Peters
From the JS& RG. The 1929 two tooth Gemmer column was an inch shorter than the 30-31 steering column.
Old 11-29-2020, 09:35 AM   #5
John
John's Avatar
The two tooth Gemmer setup for the '29 used a keyed steering wheel connection on the 43 inch shaft like the 44 inch shaft on the '30-31. The 7 tooth column had a splined steering wheel connection. A very few two tooth splined boxes did exist.
John is offline   Reply With Quote
