Old 09-08-2011, 12:51 AM   #1
Kurt in NJ
Kurt in NJ's Avatar
Default Bad Babbitt
This babbitt is bad---
The cap had some chunks of the thrust broke loose.
The crankshaft is .002 out of round.
There is a long term coolant leak through cracked exhaust ports # 2,and 3 (easily pinned)
The oil clearance between the flanges and the crankshaft thrust surfaces is .003
The crankshaft end play is .009
I am going to chop it out ---would you?
Old 09-08-2011, 06:30 AM   #2
J and M Machine
Location: 40 Mt.Vickery Rd. Southborough,MA 508-460-0733
Default Re: Bad Babbitt
Yes I would say time is definitely up on that engine.
Looks like lead babbitt from the photo.Since you have the other issues plus the rear main. I would say now's the time to do it right.
J and M Machine is offline   Reply With Quote
