04-26-2021, 06:09 AM | #1 |
Front & rear Springs
Is there a source for the eye to eye length, (perch to perch), of the Ford springs for front & rear '32, '33-34, '35-36, '37- 40, '41, '42-48. I see the green bible has the part #s for the spring assemblies, the # of leaves and their application but I can't seem to locate the eye to eye measurement. I was looking for the uninstalled length as I may have run into some NOS ones.
Thank you. |
04-26-2021, 09:12 AM | #2 |
Re: Front & rear Springs
If they are Ford springs they should have the spring assembly number stamped into the center of the top leaf.
04-26-2021, 09:55 AM | #3 |
Peruse this info: 39 in. seems to be eye to eye for front spring.
https://www.google.com/search?q=1940...hrome&ie=UTF-8 Here's rear spring info. https://www.google.com/search?q=1940...hrome&ie=UTF-8 |
04-26-2021, 10:22 AM | #4 |
Eye to eye measurements are not very useful and that is precisely why you don't see Ford specs for them in parts books.
Springs are designed and tested under a very specific load at a very specific height. A NOS spring would get you in the proximity of correct "eye to eye" but that's all - proximity. With a used spring, the eye to eye is worthless.
04-26-2021, 11:27 PM | #5 |
Ball park front.
04-27-2021, 12:14 AM | #6 |
