Old 04-23-2021, 06:00 AM   #1
russcc
Default EV8 Parts to NE Dragway swap
City: Bourne
State: MA
Price: in ad
List of EV8 parts to swap meet at Epping NH, (if not canceled because of rain).
From Top row, left to right
1. New 1.6 Manley SS Chev. Valves for flathead.
2. New, set of ’39-41 pre-bent brake lines & hoses
3. New, 42 pass, 46 p/up hub caps
4. NOS 39-41 balanced, crank mount fan
5. Used, Stewart Warner 160 mph speedo
6. New, pair of 21A-O1A brake drums
7. Used 28T cluster
8. NOS 49-53 Loadamatic distributor
9. Used, 37-48. Steering sector/worm gear
10. Used, 40’s comm. column drop, no key
11. Used, swoop top loader gear shift lever w/original deluxe V8 knob
12. Used, chrome steering column mast jacket
13. Used, 1940 Lincoln V-12, distributor, complete w/coil
14. Used, 37-41 helmet distributor
15. Used, 16T main drive gear
16. Used, 28T cluster gear
17. NOS, double sheave crankshaft pulley
18. NOS, 21A, 2 bolt timing cover
19. Used, 36-38 column drop w/key
20. Used, 35-36 column drop w/key
21. Used, Lincoln headlight rims, year & model unknown
22. New, pair of brake adapters, ’42-48 Lincoln backing plates to ’37- 48 spindles
23. Used, 37 standard gear shift knob
24. Used, convertible rear window frame, 24” x 7”
25. New, pair of Lincoln emergency brake tubes
26. Good used pair of 11A, 41 hood hinges in maroon paint
27. Used, 3 bolt timing cover
Not Shown
1. Good used 35-36 oil pan, clean.
2. Used, 1935 United Hvy duty oil bath air filter, Ford accessory
3. Rebuilt, Lockheed front & rear back plates w/hardware & new shoes.
4. NOS, Lincoln Zephyr V-12 steel heads
5. Good used pair of Lincoln V-12 exhaust manifolds
6. New Lincoln V-12 head gaskets, intake & pan gaskets, several sets.
If rain cancels the swap meet, I may be available for p/up of larger items on Saturday 4/24 by appointment in Southern coastal NH.
PM me for photos, prices or more info. Russ.
russcc is offline   Reply With Quote
