11-16-2011, 06:36 PM | #1 |
Headlights reflectors
Hi,
in the 2 bulbs reflectors, the parking bulb goes on the top or in the bottom of the reflector ? The following photo shows the parking light on the bottom position Uploaded with ImageShack.us Cheers, Charlie Saguier
Charlie Saguier Ford Model A Roaster Pickup 1928 Jeep Willys CJ-2A 1947 Jeep Willys MB Slat Grill 1942 |
11-16-2011, 06:54 PM | #2 |
Re: Headlights reflectors
Goes on top.
11-16-2011, 07:12 PM | #3 |
Hi 700rpm !
many thanks for your prompt answer ! Cheers, Charlie
11-16-2011, 08:21 PM | #4 |
Aside from looking strange, it would probably work about the same either way.
11-17-2011, 04:18 AM | #5 |
11-17-2011, 06:29 AM | #6 |
11-17-2011, 07:11 AM | #7 |
Oh yeah, it is, isn't it. The holder is mounted to the shell with the focus screw, not to the reflector.
11-17-2011, 07:53 AM | #8 |
Hi Guys,
again many thanks for your answers. Regarding the reflectors and headlamps I have another question. I bought the 2 bulbs headlight socket, but I don't know why I can't connect the socket with the 3 cables through the back headlamp socket Any idea what I'm doing wrong or maybe I'm missing something ? Some photos of how the cables goes imto the headlamp would help a lot. Cheers and tks in advance. Charlie
11-17-2011, 08:59 AM | #9 | |
A man should do what he thinks best! "The Duke" |
11-17-2011, 10:12 AM | #10 | |
I thought the bulb holder was keyed only on one side so that when the focus screw is turned the bulb would not rotate in the reflector. I don't have a set handy to double check.
11-17-2011, 10:20 AM | #11 |
It has been my experience that the repo sockets are nothing but a short waiting to happen. I prefer to rewire original sockets. They are not too hard to find at swap meets. Gar Williams
11-17-2011, 11:20 AM | #12 |
My problem is with the socket in the headlamp !!!!!!
The two on the reflector fixed perfect ! Cheers, Charlie
11-17-2011, 01:42 PM | #13 |
Charlie, I'm not sure exactly where your problem lies. Do you have the right conduits and plugs? Here is a diagram that may help you sort it all out. I'm loading both a PDF and a JPG, because I don't know which one will show better.
11-18-2011, 12:57 PM | #14 |
Hi 700rpm,
i bought two bulbs cables for headlights and I can't introduce the blue circled socket through the red circled hole in the headlamp Uploaded with ImageShack.us Maybe I need to buy something more in between ? Cheers, Charlie
11-18-2011, 01:24 PM | #15 |
Charlie,
There are 2 styles of head light buckets, 2 wire & 3 wire. Post a photo of the head light bucket, from the outside, on the bottom. Dudley |
