Old 09-20-2021, 03:59 PM   #1
34pocho
34pocho's Avatar
Default Marvel Mystery Oiler
Has anyone ever hooked up a Marvel Mystery Oiler on a Model A that feeds the cylinders through the manifold vacuum? I seen one for sale on eBay and was curious how it works.
34pocho is offline   Reply With Quote
Old 09-20-2021, 04:29 PM   #2
Werner
Werner's Avatar
Default Re: Marvel Mystery Oiler
There are two systems to inject MMO. That, what I use sprays the oil into the cylinders when the vakuum pressure under the carbureter ventury is low. That is when the engine is pushed without any drive work.
The other system, unfortunately I don't remember what it's called, injects oil at high power, that's the better way.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 09-20-2021, 06:25 PM   #3
Flathead
Flathead's Avatar
Inverse oiler.
Flathead is offline   Reply With Quote
Old 09-20-2021, 10:31 PM   #4
eagle
eagle's Avatar
I'm really not sure how injecting MM oil would be more effective than adding it to the fuel. I've seen it on Model As and its a comment item at a car show. Looks kind of vintage and "cool". MM oil in the fuel has advantages for the carb I'd think that a manifold injector would bypass. Just my thoughts. I have experience with MM oil doing good things for small engines.
Old 09-21-2021, 04:22 AM   #5
mercman from oz
mercman from oz's Avatar
AMOCO Oiler in Model A Ford
mercman from oz is online now   Reply With Quote
Old 09-21-2021, 02:22 PM   #6
Werner
Werner's Avatar
Eagle, what you write is entirely and completely correct! The addition to the fuel has the most efficient effect because the amount of fuel increases with the engine power. (Therefore I add 40 cm³ while taking fuel on the gas station.)
But there is something particularly pleasing to the eye about this old-fashioned MMO metering system, and I think it fits the Model A well. Isn't it?
Werner
Citroen 11 CV, 1947
Old 09-21-2021, 08:03 PM   #7
eagle
eagle's Avatar
It does, very cool!
Old 09-23-2021, 08:21 AM   #8
Patrick L.
Patrick L.'s Avatar
It is a pretty neat looking looking piece. And would be good with ATF for pickling the engine for the off season.
Old 09-23-2021, 09:36 AM   #9
51504bat
51504bat's Avatar
I had one on the 8ba in my '39 p/u. Problem was that I couldn't get the glass jar to seal. Made several different gaskets but never could stop it from leaking. Ended up taking it off. Its still on the shelf. Maybe this winter I'll give it another try.
Old 09-23-2021, 10:59 AM   #10
Nosetime
Nosetime's Avatar
A real one.
File Type: jpg DC2DEF10-D298-4087-AE7C-939B5B59F8D4_1_105_c.jpg (49.5 KB, 183 views)
Nosetime is offline   Reply With Quote
Old 09-23-2021, 12:42 PM   #11
Werner
Werner's Avatar
Originally Posted by 51504bat View Post
... Problem was that I couldn't get the glass jar to seal. Made several different gaskets but never could stop it from leaking. ...
Was that rubber seals? In this application, cork gasket is the better way.
MMO contains synthetic ester oil and isoalkanes as well as cycloalkanes. These attack some plastics. Rubber seals swell and then become brittle.
Werner
Citroen 11 CV, 1947
Old 09-23-2021, 01:12 PM   #12
51504bat
51504bat's Avatar
Tried both. Rubber and cork. Neither would seal completely.
Old 09-23-2021, 05:22 PM   #13
old ugly
old ugly's Avatar
OK, so i'm old and stupid, but help me understand.
what is the purpose of injecting the "MMO"?
Is it supposed to be injected into the intake manifold while the engine is running?
thanks
ou
old ugly is offline   Reply With Quote
Old 09-24-2021, 06:20 AM   #14
McMimmcs
McMimmcs's Avatar
It looks weird and looks like it doesn’t belong. I wouldn’t take one as a gift !
Old 09-24-2021, 08:03 AM   #15
Werner
Werner's Avatar
Old Ugly,
MMO has two great characteristics. The ester oil is extremely temperature stable and supports the boundary lubrication on the valve stems and also the top dead center piston + cylinder.
The most important benefit is the addition of detergents. These loosen and burn soot and ash in the combustion chambers and on the valve tulips, spark plugs.
Since the old engines always burn a lot of oil and especially simple mineral oils leave behind a lot of residue crust, it is helpful to mix such additives with the gasoline in very small doses.
It also dissolves resin deposits etc. in the fuel tank and the pipes.
Werner
Citroen 11 CV, 1947
Old 09-24-2021, 08:08 AM   #16
Sunny the Model A
Sunny the Model A's Avatar
What a curious idea, sort of like the oil injector on a two stroke saab
Sunny the Model A is offline   Reply With Quote
Old 09-24-2021, 09:40 AM   #17
old ugly
old ugly's Avatar
Old Ugly,
i take it that you like and use it?
how much would you dump into a full Model a fuel tank?
ou
Old 09-24-2021, 12:16 PM   #18
Werner
Werner's Avatar
Hi Ugly,
use approximately 1:400. That's 3.5 US fl oz on 11 gallons of fuel. Much more is not necessary and also not helpful.
Werner
Citroen 11 CV, 1947
Old 09-24-2021, 12:32 PM   #19
old ugly
old ugly's Avatar
Hi Ugly,
nice.
do you notice any difference with drivability or engine performance?
engine cleaner inside?
thanks
ou
Old 09-24-2021, 01:18 PM   #20
Werner
Werner's Avatar
The performance of the engine and its idling have remained unchanged.
The spark plug inner insulators are much cleaner. If you peer into the combustion chamber through the plug bores, you can see that all the residues gradually diminish over time.
Gerne gemacht!
Werner
Citroen 11 CV, 1947
