Old 08-28-2021, 12:52 PM   #1
nkaminar
nkaminar's Avatar
Default Anyone using an air/fuel meter?
There are two air/fuel meters that I know of that can be bought from about $80 to $160 on Amazon. The meters will give you a reading of whether your car is running rich or lean or just right while you are driving. Some welding is required. These gauges will tell you if your GAV is set right or if there is a clogged jet in the carburetor.
Is anyone running one?
File Type: jpg Screen Shot 2021-08-28 at 1.53.47 PM.jpg (11.2 KB, 21 views)
Old 08-28-2021, 03:43 PM   #2
Lawrie
Lawrie's Avatar
Default Re: Anyone using an air/fuel meter?
Not one of those ,but I use an innovate one to set up the mixture on both my A and v8s.
Lawrie
Old 08-28-2021, 03:49 PM   #3
Mister Moose
Mister Moose's Avatar
I might get one for my Turbo Eclipse when I turn the boost up to 16 psi and need to make sure it's not running too lean, but for the Model A? Don't think so.
Mister Moose is offline   Reply With Quote
Old 08-28-2021, 04:50 PM   #4
Patrick L.
Patrick L.'s Avatar
Been using tail pipe probes in diagnostic machines [ Sun] for 6 decades. They work well. But, I'm not going into stuff like this very far anymore.
Old 08-30-2021, 09:10 AM   #5
bettlesr
bettlesr's Avatar
I used an Innovate unit to set up my weber carb. After a couple of months my sensor would crap out. In the mean time it worked great.
1965 Lotus Elan S2
1930 Model A Sport Coupe
bettlesr is offline   Reply With Quote
Old 08-30-2021, 09:33 AM   #6
Kurt in NJ
Kurt in NJ's Avatar
I have thought about putting a bung in wen I put in new exhaust. In the past i ran the car on the loaded emission test NJ used to have to figure best gav adjustments (the A could pass as a 2005)
I suspect that many of the cars would run rich enough that the sensor would get contanimated quickly from being too rich
Old 08-30-2021, 09:44 AM   #7
Patrick L.
Patrick L.'s Avatar
IThe last time I stuck a probe in the A tailpipe was in the OBD1 days and it would pass. So that was what 1996 I think.
Old 08-30-2021, 10:22 AM   #8
Jim Brierley
I use an exhaust temp ga. in my Bonneville engine, it and plug readings tell me what I need to know.
Old 08-30-2021, 10:57 AM   #9
PC/SR
Had a smog test jsut for fun. The probe measured an air fuel mixture to 22/1. The guy told me I had to richen the mixture. I told him the gauge was wrong, the car would even not run with 22/1. Kinda funny
PC/SR is offline   Reply With Quote
Old 08-30-2021, 11:49 AM   #10
Patrick L.
Patrick L.'s Avatar
LOL ! I think he was off by about 10.
Old 08-31-2021, 03:17 PM   #11
MALAK
MALAK's Avatar
Yep
MALAK is offline   Reply With Quote
Old 08-31-2021, 06:16 PM   #12
nkaminar
nkaminar's Avatar
Malak, nice.
PC/SR, There must have been some oxygen getting into the exhaust somehow.
Old 08-31-2021, 06:51 PM   #13
GRutter
GRutter's Avatar
Originally Posted by MALAK View Post
Yep
How do you have the sensor mounted ?
GRutter is offline   Reply With Quote
Old 09-01-2021, 03:41 PM   #14
AL in NY
AL in NY's Avatar
I would love to put one in my 30 CCPU if I could find a way to get it to work on a 6V positive ground system.
AL in NY
AL in NY is offline   Reply With Quote
Old 09-01-2021, 08:12 PM   #15
nkaminar
nkaminar's Avatar
Al, Google 6 volt to 12 volt converter.
Old 09-02-2021, 03:59 PM   #16
Pete
Pete's Avatar
Power the meter with a small nicad or lithium battery pack mounted up under the dash. Charge the pack once a year.
