Old 07-06-2021, 01:13 PM   #1
old splicer
old splicer's Avatar
Default Isky ldb
I'm looking for a timing tag for an ISKY LDB on a 59a style cam Has approximately .290 lift
old splicer is offline   Reply With Quote
Old 07-06-2021, 01:49 PM   #2
Tim Ayers
Default Re: Isky ldb
If the lift is accurate, that's an odd one for I believe that less lift than a stock cam has.
Most stock cams have .307" or more lift.
Old 07-06-2021, 02:09 PM   #3
flatjack9
flatjack9's Avatar
Could be for an Ardun.
Old 07-06-2021, 02:34 PM   #4
Ol' Ron
Ol' Ron's Avatar
could be a "60" hp
Old 07-06-2021, 02:38 PM   #5
KiWinUS
KiWinUS's Avatar
Sides of bearing journal & lobe almost look like finish of a steel cam.
Bolt on gear makes it not a 60 unless had custom cam & gear but poster states it’s 59Ab
Old 07-06-2021, 05:19 PM   #6
Bored&Stroked
Bored&Stroked's Avatar
I believe that is an Ardun cam and it stands for "Long Duration Bigalow". Looks like it is a steel core cam - maybe created from a 32 billet. Not much lift . . .
Old 07-06-2021, 08:56 PM   #7
Pete
Pete's Avatar
Original specs for the GMC 6 LDB were:
In 26/65
Ex 65/26
Cam lift .285
In cl .018
Ex cl .018
Isky adapted the grind to many different engines. The reason it worked so well was the fairly high lift velocity. It made a lot of power at the mid to top end and would turn 8500 in the 270 Dodge hemi I had one in for road racing.
The pictured example is very likely for an Ardun conversion.
Old 07-06-2021, 09:49 PM   #8
scicala
scicala's Avatar
Does an Ardun conversion have push rods and rocker arms ? If so, that would explain the low cam lift since the rockers were probably around a 1.5:1 ratio.
Sal
scicala is offline   Reply With Quote
Old 07-07-2021, 12:14 AM   #9
Fordors
Sal
Original Ardun rocker arm ratio is only 1.2:1.
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery.
Fordors is offline   Reply With Quote
Old 07-07-2021, 09:18 AM   #10
Tim Ayers
Using that ratio, it would give you .348" of lift.
Old 07-07-2021, 09:31 AM   #11
tubman
tubman's Avatar
To put that in perspective, a stock Ford cam has a lift of .307, while the Isky MAX-1 has a .364 lift. This may not be a direct comparison, because we don't know how the lifts on the respective cams were measured.
Old 07-07-2021, 09:36 AM   #12
Tim Ayers
I know nothing about how to set up Arduns, but after watching the IronTrap video and hearing what Ronnie Roadster said, there can be clearance issues with the push rods when using a "performance" cam on these units.
Curious at what lift does the clearance issue come into play.
Old 07-07-2021, 12:03 PM   #13
frnkeore
frnkeore's Avatar
I think some of those issues were address in the Ardun thread, a short time back.
Frank
'35 Ford Model 51
'48 Ford F3
'54 Ford Tudor Mainline
frnkeore is offline   Reply With Quote
Old 07-07-2021, 12:16 PM   #14
frnkeore
frnkeore's Avatar
Here it is:
https://www.fordbarn.com/forum/showt...ighlight=ardun
Frank
'35 Ford Model 51
'48 Ford F3
