Old 10-07-2023, 02:32 PM   #1
Kube
Kube's Avatar
Default how to remove door window from '31 coupe???
So, what's the trick?
Door panel is off.
thanks guys
Old 10-07-2023, 03:14 PM   #2
A bones
A bones's Avatar
Default Re: how to remove door window from '31 coupe???
The info I've seen, tells of disengaging the rollers one at a time then rotating the top of the pane towards the front of the door. Lift it on out..
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 10-07-2023, 03:44 PM   #3
Big hammer
31 Tudor, top of the door has a cover with 3-4 screws, remove the cover and the glass comes out the top. As for the rollers and regulator I’ve forgotten, get the rollers out of the track and push the glass up and out.
If you don’t want to save the glass just use a Big Hammer, sorry couldn’t resist ;-)
get a bigger hammer tap done
Old 10-07-2023, 03:48 PM   #4
Tom Endy
Tom Endy's Avatar
Here is how you go about it on a 31 Victoria. I think the slant window doors are much the same.
http://www.santaanitaas.org/wp-conte...ing-_4-08_.pdf
Tom Endy
Tom Endy is offline   Reply With Quote
Old 10-07-2023, 06:39 PM   #5
Kube
Kube's Avatar
Thanks guys. All out and good to reassemble.
