Old 10-25-2020, 04:05 AM   #21
updraught
updraught's Avatar
Default Re: Oil Breather tube 20 inch flex tube
There's the Stipe one
https://www.specialtymotorcams.com/d...by-control-008
updraught is offline   Reply With Quote
Old 10-25-2020, 07:51 AM   #22
aermotor
What about running a hose with a PCV valve over to the intake manifold?
John
aermotor is offline   Reply With Quote
Old 10-25-2020, 02:59 PM   #23
Purdy Swoft
Purdy Swoft's Avatar
I once thought about using a PCV but decided not to . If I used the PCV it would cause the engine to have to reburn the fumes . I figure burning the fumes would slightly weaken the charge in the combustion chambers and help the spark plugs to stay oily and weaken the spark . Too hell with the fumes , I use a Fumaze !!!
Old 10-25-2020, 05:01 PM   #24
Synchro909
Synchro909's Avatar
IMO, you will never notice any weakening of the mixture. I have done that for years and never even wondered whether that was happening. It helps with any rear main leak too.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 10-26-2020, 12:13 AM   #25
Ruth
Not to mention sucking all the byproducts from combustion from your crankcase (unburned gas, water and acids). It's a good thing!
Ruth
