06-27-2020, 01:46 PM | #1 |
AA truck 4 speed question.
A friend is restoring a WW2 Ford of Canada bren gun carrier . It is fitted with the Warner 4 speed same as the AA truck . He is missing the shifter but has the tower . He will have to modify a shifter as it is remotely operated . I do have the bottom half of a shifter( which had been cut) out of a spares 4 speed but the slot in the half ball is 90 degrees offset from the regular slot which is at 9 oclock .This cut shifter would only work in a tower where the pin hole is at 6 oclock . The mystery is that the tower it came out of is the regular 9 o clock style so how it selected gears is a mystery as it would have been 90 degrees misaligned . The question is are there two types of tower pin holes ,9 o clock and 6 o clock ???
John in same place same weather Suffolk County England . |
06-27-2020, 01:57 PM | #2 |
Re: AA truck 4 speed question.
Is it possible somebody bent the shifter for a special application?
06-27-2020, 02:01 PM | #3 |
John
There are two types of shifters. One where the ball is part of the shifter (later) and one where the ball is a separate piece and is pinned to the shifter. You may have the pinned type where the ball has sheared the pin and rotated.
Bill Cilker, Jr Unrestored 190A Victoria 45B, 160B & 189A Victoria Association President |
06-27-2020, 02:06 PM | #4 |
It looks like the shifter comes straight up out of the transmission.
06-27-2020, 03:05 PM | #5 |
Thank you Bill you hit the nail on the head .I do have a late type and the earlier and you can plainly see the late style is "one piece" . The transmission that shifter came out of showed very little wear and probably got taken out of service when the ball pin sheared . I have already mailed the cut shifter to the man and will tell him to try to revolve the ball back to where it should be . It is very rusty so no doubt frozen so a lot of heat will be required no doubt . Thanks again mystery solved !!!
John in cloudy cool rain showers Suffolk County England . |
06-28-2020, 05:55 AM | #6 |
John in Suffolk County England . |
