Old 03-30-2013, 08:32 AM   #1
Bobs32
Bobs32's Avatar
Default Will a '42-44 distributor work on a '48 engine ?
I had my engine rebuilt and I don't know if the guy pulled a fast one on me or if he just had both a '42-'44 and a '46-'48 in his shop and got them mixed up or what, but he gave me back my old V style cap with the old parts he replaced. Will I run into trouble running a '42-'44 distributor on my '48 mercury engine ?
Bobs32 is offline   Reply With Quote
Old 03-30-2013, 08:58 AM   #2
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Re: Will a '42-44 distributor work on a '48 engine ?
Shouldn't be a problem as the caps are interchangeable with clips and or bail to run eithe one. Each has their own look...
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 03-30-2013, 09:06 AM   #3
rotorwrench
rotorwrench's Avatar
The crab cap is certainly more user friendly than the weather sealed unit used through 48.
Old 03-30-2013, 09:25 AM   #4
Bobs32
Bobs32's Avatar
Let me see if I am understanding this, it very well might be the only thing that was changed is that a crab cap was put on my distibutor ?
Old 03-30-2013, 09:31 AM   #5
BUBBAS IGNITION
Originally Posted by bobs32 View Post
let me see if i am understanding this, it very well might be the only thing that was changed is that a crab cap was put on my distibutor ?
could very well be,
the only difference is the side clips vs a wire bail on the two style of caps..
[email protected]
Old 03-30-2013, 09:39 AM   #6
Bobs32
Bobs32's Avatar
If I had the "V" style cap it would of needed the wire bail correct ?
Old 03-30-2013, 10:32 AM   #7
Bobs32
Bobs32's Avatar
If so, I've got the side clips now. My distributor must of gotten switched.
Old 03-30-2013, 10:46 AM   #8
oldskool
oldskool's Avatar
also check the rotor as 42-44 is different from 46-8 crab takes 21A -12200
oldskool is offline   Reply With Quote
Old 03-30-2013, 10:54 AM   #9
ken ct
Crab cap has a gasket behind it,the rotor is longer on a 42. Basic dist is same as 48. Diff. clips,rotor and cap. I would also use the rubber nipples on the cap holes theres 9 of them. ken ct.
ken ct is offline   Reply With Quote
