Old 08-03-2019, 05:32 AM   #1
truckdog62563
truckdog62563's Avatar
Default Wheel 01AS 1015B - Early Chassis Catalog Reference?
I posted this question over on FTE but have found no one with an early edition of the Green Bible. Maybe better luck here.
I’m looking for anyone that might have an early 1940s original paper Chassis Catalog that might include reference to this wheel? I have the late 1940s Green Bible but it is silent to it. My wheel references show it is a 15” x 5.50” one piece, type “F” drop center, 5 x 5.5” pattern, “Change Over” wheel available on Commercial models 1940-1946. It is Kelsey Hayes #23427. Normally Change Over wheels were aftermarket and not assigned Ford numbers, as was the case with the earlier 1936 to 1939 version of this wheel having the 5 x 10.25” pattern. But this later wheel got assigned a Ford number. I’ve added to my eBay watch list a couple of ‘38-‘42 editions of the catalog in case nobody comes up with an answer. The reason this might matter is Ford’s practice of deleting obsoleted/superseded/interchanged parts from subsequent publications of the Green Bible. Thx. Stu
Stu McMillan
Marmon-Herringtons
truckdog62563 is offline   Reply With Quote
Old 08-03-2019, 09:14 AM   #2
L-head
Default Re: Wheel 01AS 1015B - Early Chassis Catalog Reference?
I have a Ford and Mercury chassis parts and price list from October 1941. I looked at it twice and do not see that number listed in it.
L-head is offline   Reply With Quote
Old 08-03-2019, 12:01 PM   #3
barnstuf
It is not in the 1948-55 Ford Truck Chassis Parts Reference Book.
barnstuf is offline   Reply With Quote
Old 08-03-2019, 01:03 PM   #4
truckdog62563
Thanks for looking, guys. I have several of the original ‘48 to ‘56 catalogs too, and three OSI catalogs. The OSI of 1/51 I thought might be likely to show it obsoleted as it does the equally mysterious two piece wheel 7RC 1015 that’s listed in the Service Manual, but no such luck.
So often we get questions from new guys wanting to know if a 15” wheel was an option on these early trucks, and the standard answer is always no. Only 16” wheels prior to 1953. But the NWRA and K-H records of this 01AS 1015B make it an open question.
The 7RC 1015 I’ve had some success tracking down with the help of James K. Wagner and the good folks at the Benson Ford Research Library. It ultimately saw production in 1953 after two number changes to TAAA 1007A / K-H 36877.
Also this week, which brought all this back to mind, I came upon the below 1938 Firestone reference for their “Change Over” 15” wheels for both the 5 x 10.25” and 5 x 5.5” patterns. So there are examples of 15” wheels having been available for these early trucks. Stu
Stu McMillan
Marmon-Herringtons
Old 08-03-2019, 02:37 PM   #5
flatjack9
flatjack9's Avatar
I have catalogs dated 2/20/40 and 5/41 with no reference to that wheel.
Old 08-03-2019, 03:47 PM   #6
truckdog62563
Thanks, looks like there’s no point in me buying more editions of the Catalog. This might just be another example of Ford’s left hand and right hand going different directions. The example of the 7RC 1015 might illustrate it. No Chassis Catalog ever listed the number. The 1949 Service Manual lists and fully describes it, and the 1/51 OSI obsoletes it with no substitute cited. Yet Ford engineering drawings from 1947 to 1952 show it with number changes from 7RC 1015 to 7RC 1007A to TAAA 1007A. The 3/53 Chassis Catalog finally lists 7RC 1007A as do NWRA and K-H references. The 7/53 OSI changed the number to TAAA 1007A to now agree with the engineering records, and it’s listed that way again in the 1/54 Chassis Catalog. Following that it is obsoleted again and replaced by TAAA 1007B, a wheel using the same rim and center disc but having less offset. Stu
Stu McMillan
Marmon-Herringtons
Old 08-03-2019, 04:33 PM   #7
flatjack9
flatjack9's Avatar
I have a Jan, 1955 OSI catalog which notes an 01AS 1015 A.(noB). Obsolete and not replaced.
Old 08-03-2019, 05:39 PM   #8
truckdog62563
Yes, I see it too. Would love to know what the difference was between this A and B. I again checked the 7/53 and 1/51 OSIs and find no answer. I’ve also never found an earlier OSI listed for sale. Maybe I should watch closer for that. Thx. Stu
Stu McMillan
Marmon-Herringtons
Old 08-06-2019, 01:23 AM   #9
Manuel
Hi, my book says -
01AS 1015A Wheel assy - 18x3.62 (used with 6.00x18 tyres) for 112" Comm 114" & 118" (when specified) 1941-42.
Manuel in Oz
Manuel is offline   Reply With Quote
