Old 06-16-2021, 07:51 PM   #1
Conaway2
Conaway2's Avatar
Default Front Cross Member Question
The front cross member on the frame of my newly-acquired ‘29 sport coupe project is not riveted, but bolted- and not all the bolts are apparently there. As I recall, these frame members were all riveted, weren’t they ??
Thanks - Jim
Conaway2 is offline   Reply With Quote
Old 06-16-2021, 08:46 PM   #2
Oldbluoval
Oldbluoval's Avatar
Default Re: Front Cross Member Question
Rivets
And the ones on top need to be flush with the frame otherwise
fender mount problem
Oldbluoval is online now   Reply With Quote
Old 06-16-2021, 08:47 PM   #3
Oldbluoval
Oldbluoval's Avatar
Rivets
Not sure about double post! Oh well
Old 06-18-2021, 04:47 PM   #4
john in illinois
john in illinois's Avatar
It is probably a replacement. The owner used bolts instead of rivets.
If all the bolts are there it would be easier just to use it.
Replace missing bots and check all for tight.
If you decided to rivet you may find holes were drilled larger for bolts.
I have a friend that has driven for several years with bolted x member.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 06-18-2021, 08:16 PM   #5
Conaway2
Conaway2's Avatar
Thanks for all the responses. I’ll keep this crossmember, as it’s in very good shape. I will put the missing bolts in. I’d like to find good quality carriage bolts for the holes on top of the frame- any suggestions ?
Thanks - Jim
Old 06-18-2021, 08:24 PM   #6
Y-Blockhead
Y-Blockhead's Avatar
McMaster-Carr has Grade 8 carriage bolts in all sizes.
Old 06-18-2021, 09:56 PM   #7
Oldbluoval
Oldbluoval's Avatar
Carriage bolts won’t get it
Frame needs to be flush so fenders will lay flat
Flat head machine screws with nuts underneath as a minimum
Old 06-19-2021, 07:06 AM   #8
sofield
Contact Bolt Depot in MA. You can get the six necessary 1/4" recessed bolts that will be flush with the top of frame including the other 8 bolts for the sides and bottoms of the frame in #8.
sofield is offline   Reply With Quote
Old 06-19-2021, 11:17 AM   #9
katy
katy's Avatar
#8?, #8 is only about 5/32" OD
Old 06-19-2021, 04:34 PM   #10
john in illinois
He probably meant grade 8 or maybe not.
John
Welcome each day
Old 06-19-2021, 05:55 PM   #11
sofield
John
I did mean grade #8
Old 06-20-2021, 07:42 AM   #12
Conaway2
Conaway2's Avatar
Thanks to everyone - I did find grade 8 bolts at McMaster-Carr and the Bolt Depot.
Jim
Old 06-20-2021, 08:37 AM   #13
Bob Bidonde
Bob Bidonde's Avatar
My Coupe has 50,000 miles on a bolted-in front crossmember. However the bolts are line fit into their holes for excellent shear, and the bolts are a high tensile strength for tension. There are not gaps between the crossmember and frame rails.
If you rivet the crossmember, the rivets must fill their holes.
Bob Bidonde
Old 06-20-2021, 10:25 AM   #14
katy
katy's Avatar
John
Thanks, grade 8 would make more sense than #8
Old 06-20-2021, 02:02 PM   #15
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Mine was welded in.
