Old 06-02-2021, 07:50 PM   #1
JamesC123
Default Bending the front axle
Does anyone know if you can bend the front axle? My left front tire leans inward about !/2 inch.
JamesC123 is offline   Reply With Quote
Old 06-02-2021, 08:14 PM   #2
nkaminar
nkaminar's Avatar
Default Re: Bending the front axle
Yes. Bend cold. You are going to need some big force. Use the gauge rods that mount in the four holes. See "Adding Caster to the Axel" https://www.fordbarn.com/forum/showt...ster&showall=1
Old 06-02-2021, 09:12 PM   #3
Synchro909
Synchro909's Avatar
To a truck repair workshop, bending a Model A axle is like breaking a pretzel.
Old 06-03-2021, 10:06 AM   #4
katy
katy's Avatar
Are you sure that it's the axle? I had a similar problem where it was the spindle.
Old 06-03-2021, 10:46 AM   #5
jayvee34
jayvee34's Avatar
Not only the spindle, but also the king pin or a combination of both. I would certainly
check those out before pulling the axle.
IN GOD WE TRUST - SEMPER FIDELIS
John
jayvee34 is offline   Reply With Quote
Old 06-03-2021, 10:52 AM   #6
Y-Blockhead
Y-Blockhead's Avatar
I once had a '72 Ford Econoline Van with the "Twin I-Beam" front suspnsion. I took it in for alignment and they chained the axle to the rack and bent the axle using a large bottle jack.
Maybe they could do the same for you with the axle still in the car?
