Old 10-23-2021, 11:23 AM   #1
gajeepguy
Default 1939 convertible windshield stainless
Guys, how do I remove the stainless moldings from the windshield rubber? Does it just pull out? I don't want to damage it. Thanks,
gajeepguy
gajeepguy is offline   Reply With Quote
Old 10-23-2021, 11:53 AM   #2
Kube
Kube's Avatar
Default Re: 1939 convertible windshield stainless
gajeepguy
Remove inner window moldings, both right and left as well as center piece.
Remove glass with rubber gasket from both sides.
From outside of car, remove small stainless piece that covers ends of each stainless molding. This is located at the center - bottom.
Now remove the trim piece. You should start at the center bottom and may need to tap the edge as you go along.
Often times the trim is stuck a bit or God forbid some idi-- glued it.
Old 10-23-2021, 02:06 PM   #3
Karl Wescott
Karl Wescott's Avatar
To expand on Kube's explanation, the stainless attaches to the body not the rubber. The glass with rubber seal are removed first, hopefully not disturbing the stainless trim.
Karl Wescott is offline   Reply With Quote
Old 10-25-2021, 08:16 AM   #4
gajeepguy
Thanks, guys. I'll give it a try....... -RG
Old 10-25-2021, 09:39 PM   #5
Veeder
Go at it very very slowly
Veeder is offline   Reply With Quote
