Old 10-22-2021, 11:40 AM   #1
PeteVS
PeteVS's Avatar
Default Universal retaining washer
I'm putting things together. The bolt and washer that retain the universal to the transmission output shaft: Does the small tab on the washer face out to the bolt head or in towards the front half of the universal? Thanks!
(This is a "39 trans.)
Don't never get rid of nuthin!
PeteVS is offline   Reply With Quote
Old 10-22-2021, 12:06 PM   #2
Kube
Kube's Avatar
Default Re: Universal retaining washer
Pete, Is you look close, the washer has a cone to it. The cone faces away from the engine. In other words, the convex side is nearest the head of the bolt.
The cone is what gives the washer a locking characteristic.
Old 10-22-2021, 01:17 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
The REAL washer! DD
Click Links Below __
T5 W/TORQUE TUBE
V8COOPMAN is online now   Reply With Quote
Old 10-22-2021, 03:06 PM   #4
Lawrie
Lawrie's Avatar
The small tab locks I into the spline on the engine side of the u/joint. to stop the washer from turning.
Lawrie
Lawrie is offline   Reply With Quote
Old 10-22-2021, 05:06 PM   #5
19Fordy
19Fordy's Avatar
Would it be ok to install it using an impact wrench?
Old 10-22-2021, 06:16 PM   #6
PeteVS
PeteVS's Avatar
Thanks all. I was in a hurry so I put it in with the "tab" towards the bolt head. I don't see if my washer has a dome to it. I have at least one more. I'll double check and if they're all the same, I'll just have to take the trans out and redo it. At least I didn't get around to get the engine in. Do any of the vendors have the "real" washer? (That's what's known as a Belleville washer.)
Old 10-22-2021, 06:20 PM   #7
Kube
Kube's Avatar
If yours has the tab, then it's correct. However, you installed it backwards. I'd have serious anxiety wondering when it will decide to back out.
Old 10-22-2021, 08:33 PM   #8
oleschool36ford
oleschool36ford's Avatar
My U-joint capscrew has red loctite on the threads. My first 36 Ford which I did not build had the u-joint capscrew come out and wedged between the u-joint and housing while at a stoplight. Since I could not go forward, I backed up and the screw unwedged and I drove the car for a month before I fixed it. That is the car in pic at the left.
oleschool36ford is offline   Reply With Quote
Old 10-22-2021, 09:33 PM   #9
19Fordy
19Fordy's Avatar
The OEM Bellville washer looks like this and also is installed with a lock washer.
https://www.fordbarn.com/forum/showthread.php?t=295627
There's one on Ebay right now but i would contact the seller to confirm bolt size before buying to find out if it's the real deal as he doesn't show a lock washer and it's difficult to see if it is concave. Shipping seems a bit high but, the total price is what they seem to be selling for these days.
https://www.ebay.com/itm/25445264726...3fc2%7Ciid%3A1
Old 10-22-2021, 09:35 PM   #10
petehoovie
petehoovie's Avatar
Originally Posted by 19Fordy View Post
The OEM Bellvue washer looks like this and also is installed with a lock wasker.
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 10-22-2021, 09:43 PM   #11
DavidG
DavidG's Avatar
The earlier version of the subject washer has no tab on it and I agree that in addition to the Belleville washer, a split lock washer was used as well.
Old 10-23-2021, 01:09 PM   #12
Kube
Kube's Avatar
I did not realize there was a first generation washer even though I had witnessed both with / without the tab. I continue to learn. Thanks David.
I did know there was a split type lock washer involved...
Old 10-23-2021, 01:21 PM   #13
Mart
Mart's Avatar
If overtightened they can flatten or even cup the wrong way. The only ones I have seen have had no tab.
I have seen a modern replacement type that has a tab.
Mart.
Old 10-23-2021, 01:36 PM   #14
DavidG
DavidG's Avatar
The dominant form of lock washer that I have encountered on originals was the 'shake-proof' with striations on both sides.
Old 10-23-2021, 02:24 PM   #15
Kube
Kube's Avatar
Agreed Dave. I tend to not use old lock washers unless absolutely necessary. As you know, they do lose their "gripping" strength.
