Old 08-25-2021, 07:57 AM   #1
samsonized
Default throwout bearing
what throwout bearing do you use on a model a if you are using a v8 clutch disc and pressure plate
samsonized is offline   Reply With Quote
Old 08-25-2021, 10:09 AM   #2
Mulletwagon
Mulletwagon's Avatar
Default Re: throwout bearing
My Tudor has a lightened flywheel and V-8 pressure plate (three finger) and uses the standard Model A throwout bearing.
Mulletwagon is offline   Reply With Quote
Old 08-25-2021, 10:31 AM   #3
rotorwrench
rotorwrench's Avatar
The model A release bearing and hub will work the V8 clutch cover. Make sure that the clutch disk hub doesn't bottom against the the flywheel/pilot bearing area. Some disks will after flywheel surfacing and it can cause a lot of problems. Use an old input spline to put the the disk up to the flywheel surface and make sure the disk face fully contacts the flywheel surface with a bit more hub clearance to allow for wear on the friction surfaces.
Use an original type 9-inch clutch cover with flyweights and adjustable fingers if you can. Some of the new 8N tractor 9-inch type clutches are crap so avoid them if possible.
Old 08-25-2021, 11:07 AM   #4
Step-down
Step-down's Avatar
My 2 cents is pay attention who mtn the bearing . I’m not saying ones better then the other but I’ve learned the hard way and there’s lots of labor to replace theses bearings
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 10-18-2021, 08:28 AM   #5
dmaxweb
dmaxweb's Avatar
Is this the correct bearing for a stock single plate clutch?
dmaxweb is offline   Reply With Quote
Old 10-18-2021, 08:58 AM   #6
samsonized
thanks
Old 10-18-2021, 09:00 AM   #7
dmaxweb
dmaxweb's Avatar
Originally Posted by samsonized View Post
thanks
That is a question I have, not an answer.
Old 10-18-2021, 09:05 AM   #8
samsonized
2065 is the correct throwout bearing
Old 10-18-2021, 07:35 PM   #9
redmodelt
redmodelt's Avatar
Also make sure it is mounted the correct direction. Not unkown for someone to put it on backwards.
