Old 08-31-2020, 06:01 PM   #1
41panelmark
41panelmark's Avatar
Default Helmet distributor 12 volt options?
Is there a part available for the Helmet distributor that is 12 volt instead of 6 but it still looks like the old style coil?(not the later coils used in the 60's cars and trucks).
thanks in advance guys.
41panelmark is offline   Reply With Quote
Old 08-31-2020, 06:03 PM   #2
35fordtn
35fordtn's Avatar
Default Re: Helmet distributor 12 volt options?
Skip Haney can rebuild your original coil to negative ground
35fordtn is offline   Reply With Quote
Old 08-31-2020, 06:08 PM   #3
41panelmark
Thanks, I will check with him on the 12 volt thing also.
Old 08-31-2020, 06:09 PM   #4
35fordtn
35fordtn's Avatar
He uses the same coil for 12 and 6 the only difference is the polarity and resistor used
Old 08-31-2020, 06:12 PM   #5
41panelmark
Thanks, do you have his contact information handy?
Old 08-31-2020, 08:47 PM   #6
JSeery
JSeery's Avatar
Old 09-01-2020, 01:17 AM   #7
V8COOPMAN
V8COOPMAN's Avatar
Click Links Below __
T5 W/TORQUE TUBE
Old 09-02-2020, 09:35 AM   #8
CaliforniaBorn36
CaliforniaBorn36's Avatar
Skip's email.
[email protected]
CaliforniaBorn36 is offline   Reply With Quote
