Old 11-23-2017, 07:31 PM   #1
Step-down
Step-down's Avatar
Default Duel strombergs / ford crab
I've done my search with regards to running a ford crab dissy with duel stromberg Carburator on a 59 . Running manifold Vacum . Will there be a noticeable performance issue from low vacum .
Happy Thanksgiving
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 11-23-2017, 08:07 PM   #2
Talkwrench
Talkwrench's Avatar
Default Re: Duel strombergs / ford crab
Depending on the engine, manifold you may not get too much difference. Just fitted a slingshot manifold with 97's and I can still get 21 hg at idle and there's not that much difference driving vacuum.
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 11-23-2017, 11:19 PM   #3
flatheadmurre
flatheadmurre's Avatar
The crab distributor has an adjustable vacuumbrake so it´s easy to adjust to fit your setup.
Old 11-24-2017, 01:31 AM   #4
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
no problem as it uses manifold vac and is very adjustable......
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 11-24-2017, 03:29 PM   #5
Step-down
Step-down's Avatar
Thanks
Weiland manifold , Bubbus dissy , max 97 ..... This is the winter plan ...
