Old 09-24-2021, 07:17 PM   #1
Billybob57
Default Motor seized
Have a 1931 Model A that sat for 20 years. It was running fine before it was stored. Tried to manually turn the motor over with the hand crank and it won't move. Suggestions?
Billybob57 is offline   Reply With Quote
Old 09-24-2021, 07:30 PM   #2
Step-down
Step-down's Avatar
Default Re: Motor seized
Hopefully it’s in the car and clutch isn’t stuck . Put in third gear and rock it forward and backwards
Most folks brew up 50~50 mixture and drop into spark plug hole . Is there oil in the pan o thick as hell
She may break free , I’ve also pulled them with tow rope with other car
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 09-24-2021, 07:35 PM   #3
Step-down
Step-down's Avatar
One last trick
I’ve put a Electric cooking element under the engine on low and keep it on until the head feel warm and then start to rock her in gear
Don’t burn the place down please
These old Irons have memory , last time she ran it was warm LOL
Old 09-24-2021, 07:43 PM   #4
Billybob57
What is the 50/50 mixture? I've been told transmission fluid and diesel fuel
Old 09-25-2021, 06:39 AM   #5
trevorsworth
trevorsworth's Avatar
I used ATF/MMO.
trevorsworth is offline   Reply With Quote
Old 09-25-2021, 07:02 AM   #6
rotorwrench
rotorwrench's Avatar
Check the water pump. They can seize up too. Valves can stick and cause blockage of cam movement. Marvel Mystery Oil in the cylinders can help loosen things up. Be prepared to dump what oil is in the pan and reservice it after it frees up. The MMO works its way through the rings and down into the pan.
Old 09-25-2021, 07:58 AM   #7
midgetracer
midgetracer's Avatar
Snyders sells a tool that replaces the starter and is turned with a socket and breaker bar. I have used this tool on the most seriously stuck engines with much sucess. By removing the starter you will know if it is the bendix locked on the ring gear also.
midgetracer is offline   Reply With Quote
