06-20-2020, 01:54 PM | #1 |
Changing from Positive to Negative ground
I would like to know what is involved in changing a car from positive to negative ground. I think I have a good idea on this but I am guessing there is a list of things that need to happen from the gauges to the generator.
Thanks in advance. |
06-20-2020, 02:16 PM | #2 |
Re: Changing from Positive to Negative ground
What are you trying to accomplish? I think it involves the coil and ammeter wiring, plus maybe new battery cables. It really is unnecessary though.
06-20-2020, 02:54 PM | #3 |
If you are still 6 volts leave it alone, you won't gain any benefits. Changing 12 volts is good because you will be compatible with modern electronics. What are you trying to do?
Charlie Stephens |
06-20-2020, 03:07 PM | #4 |
Dang, that is what I thought. I am trying to run some LED bulbs or entire units for the rear taillights. All of the above require Neg. ground.
06-20-2020, 03:26 PM | #5 |
There are LEDs that are Pos earth out there
06-20-2020, 03:33 PM | #6 |
06-20-2020, 06:00 PM | #7 |
This may also be helpful.
This is a recent thread and quite thorough. I'd recommend checking that one out if you haven't already. Mike https://www.fordbarn.com/forum/showt...dim+headlights |
06-21-2020, 06:45 PM | #8 |
Thanks very much guys, this helps a lot. This is why I love this forum, lots of knowledge and help here as per usual.
