Old 10-03-2021, 03:42 PM   #1
Rgejr
Default Isky 1023
I am building my Flathead with parts i have saved since the late 60’s. Had fun collecting them as a kid with my Dad. Time has come to put it all together. Would anyone happen to have any cam specs at all for the Isky 1023 for the 49/53 ? I have already tried calling Isky but could not get any info. Thanks Ron in Ft.Myers, Fla.
Rgejr is offline   Reply With Quote
Old 10-03-2021, 05:15 PM   #2
F1 MIKE
F1 MIKE's Avatar
Default Re: Isky 1023 MUSHROOM TRACK.
In-23-68 .375 lift ex-62-18 .345 lift. In .014 ex .014 . Large bore and stroked mercurys.
F1 MIKE is offline   Reply With Quote
Old 10-03-2021, 06:24 PM   #3
Pete
Pete's Avatar
Special mushroom lifters required for that cam along with special back spot facer tool to machine block.
Old 10-03-2021, 07:02 PM   #4
chain drive
what is the center line?
chain drive is offline   Reply With Quote
Old 10-04-2021, 01:09 AM   #5
frnkeore
frnkeore's Avatar
In 271 duration, 112.5 ICL
Ex 260 duration, 112 ECL
Or 112.25 LSA
Frank
'35 Ford Model 51
'48 Ford F3
'54 Ford Tudor Mainline
frnkeore is offline   Reply With Quote
Old 10-04-2021, 07:56 AM   #6
Bored&Stroked
Bored&Stroked's Avatar
Hopefully you read Pete's post very carefully - your cam is for usage with specially made "mushroom lifters" - it is not designed for any lifter that you can buy today.
So, if you have the lifters and the back-cutting tool to prep the block, then you have what you need - if you don't, then you shouldn't attempt to use this cam.
Old 10-04-2021, 11:13 AM   #7
Ol' Ron
Ol' Ron's Avatar
I had a friend that used one at Danbury speedway back in the 60's. Wasn't worth the effort.
Old 10-04-2021, 03:18 PM   #8
Pete
Pete's Avatar
A small group of us was sitting around talking to Isky back in the 50's and someone asked how the 1023 and 1024 were working out.
His exact comment was, "now why did I ever design those?".
Old 10-05-2021, 07:18 AM   #9
Ol' Ron
Ol' Ron's Avatar
I think the reason was for a faster lift rate??????
Old 10-05-2021, 07:41 AM   #10
Jay in Mass
With all of that good advice, I think that it should be used as a wall hanger.
Jay in Mass is offline   Reply With Quote
Old 10-05-2021, 08:11 AM   #11
Bored&Stroked
Thanks Pete . . . loved the story about Ed!
Old 10-05-2021, 03:49 PM   #12
Pete
Pete's Avatar
That is true, Ron, but Ed was refering to the marketing success of the cam which was next to zero.
The theory of the larger diameter lifter was ok but remember, he had the 404A at the time which was one of his biggest sellers.
Old 10-09-2021, 02:45 PM   #13
Rgejr
I have installed the cam in the block with stock diameter tappets so i could examine the contact area on both sides of the ramp. Also with the .100 smaller diameter there will be approx 20 degrees lost on both sides of the ramp which may end up working just fine. This will be an interesting experiment for sure. Different combinations along with trial and error are part the fun. Thank you to all that responded.
Old 10-09-2021, 03:41 PM   #14
V8COOPMAN
V8COOPMAN's Avatar
There ARE some folks that responded to you in this thread that DO KNOW SOME STUFF! You SHOULD take their advice seriously.
Report back here after you fire-up your engine and tell us about the trial & error "fun" that you had. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 10-09-2021, 04:27 PM   #15
glennpm
glennpm's Avatar
Changing the cam and adjusting clearances is not much fun with a flathead, very different than an OHV motor.
"Report back here after you fire-up your engine and tell us about the trial & error "fun" that you had. DD" :-)
Glenn
Old 10-09-2021, 09:22 PM   #16
Ol' Ron
Ol' Ron's Avatar
I don't think it a good idea. However, we might learn sumpin.
Gramps
Old 10-10-2021, 01:28 AM   #17
frnkeore
frnkeore's Avatar
My question is, if that cam is designed for a radius lifter, won't the edge of the stock lifter cut into the cam flanks?
Frank
'35 Ford Model 51
'48 Ford F3
Old 10-10-2021, 06:20 AM   #18
KiWinUS
KiWinUS's Avatar
Designed for mushroom lifter. Not radius lifter. Big difference.
Old 10-10-2021, 07:01 AM   #19
JWL
Yes, a big difference. BUT, if the lobe remains on the lifter face, without edging, it would not matter if the lifter was a mushroom or not. And, it seems unnecessary for such a lobe profile design to call for the larger diameter lifter face?
JWL is offline   Reply With Quote
Old 10-11-2021, 01:49 AM   #20
frnkeore
frnkeore's Avatar
If it is a mushroom lifter and larger than 1", it can have higher cam lift rate than the standard 1" lifter. The max lift rate for 1" lifter with a .008 margin = .0085866 per degree. What is the diameter of the mushroom lifters?
Here too, the lifter edge can run into the cam lobe, if that lift rate is exceeded. So, if possible, the lift rate needs to be checked.
Frank
'35 Ford Model 51
'48 Ford F3
