04-12-2017, 06:09 PM | #1 |
A Minor Generator Painting Tip
When I sandblast and paint the rear end plate on the generator, I make a tapered wood plug to keep all dust and grit out of the bearing.
I found that if I use a can opener to remove the lip of the empty cocoa can, it will be a perfect fit to the locating ring on the end plate. This keeps the paint off the brush holders, and makes a good support while the paint dries. |
04-12-2017, 08:23 PM | #2 |
Re: A Minor Generator Painting Tip
We need more good tips with images. Would solve a lot of Qs..
Good enough.. Isn't. |
04-12-2017, 09:46 PM | #3 |
interesting, i bet a mixed nuts can would be roughly the same diameter as well.
1929 Model AA - Need long splash aprons! |
04-13-2017, 09:32 AM | #4 |
Oh Oh. I can see me going through a lot of mixed nuts and cocoa trying to find the best generator support.
04-13-2017, 10:28 AM | #5 |
you make it sound like thats a bad thing! Have a beer or twelve with the nuts and add some baileys to the hot cocoa and you will find out in no time
04-13-2017, 11:37 AM | #6 | |
I have a tough time throwing away empty cans. They always seem to come in handy for holding things like an armature with an end plate. Especially the tall juice cans. Great for soaking carb parts in too. |
04-14-2017, 02:04 AM | #7 |
I think I showed this before, but to protect the field windings while sandblasting and painting, I cut two aluminum discs that fit snug inside the case, and are held tight with a 1/4" x 4 1/2" bolt.
04-14-2017, 08:53 AM | #8 | |
Where there's a will..
04-14-2017, 09:58 AM | #9 |
Good idea Tom. It seems that sand will always find a way to get in, kind of like mice. If you find that sand still gets in, you can cut a disc from a plastic bag just a little larger than the aluminum disc with a bolt hole in the middle and use it for a gasket to be sure of a seal.
04-14-2017, 10:36 AM | #10 | |
I've always wanted my own blast cabinet, I'll tell the wife you've pushed me over the edge! She'll need your # |
04-14-2017, 01:39 PM | #11 | |
You're certainly right about the sand gets everywhere. I even wish my blast cabinet was outside instead of the basement. |
04-14-2017, 03:00 PM | #12 | |
