01-20-2015, 07:09 PM | #1 |
Oil pressure
With the 1949-1953 Ford V8, what oil pressure reading should I be seeing with motor warmed up. What oil pressure at idle? What oil pressure at 35-40 mph? I am running 10W-40 Kendall GT oil. Thanks....Nick
01-20-2015, 08:11 PM | #2 |
Re: Oil pressure
What oil pressures are you showing for your engine at that speed? Ed
01-20-2015, 08:14 PM | #3 |
Re: Oil pressure
At idle, very low, maybe 5-10 lbs.....running 35-40 mph maybe 25-30 lbs...
01-20-2015, 08:52 PM | #4 |
Re: Oil pressure
The standard is 10psi per 1000 rpms. Sounds like you're okay.
Lonnie |
01-20-2015, 10:06 PM | #5 |
Re: Oil pressure
Why don't you tell a bit more about the history of the engine, there's no specific answer to your question...
Karl |
01-21-2015, 09:06 AM | #6 |
Re: Oil pressure
www.fordcollector.com Last edited by G.M.; 01-21-2015 at 10:43 AM. |
01-21-2015, 10:01 AM | #7 |
Re: Oil pressure
My 8BA numbers are about the same as G.M.'s. I use Castrol 20W50.
However, I am finding that some stores near me (Wal-Mart) no longer carry Castrol 20W50. I wonder if different oil pressure sending units will produce different readings on the same engine? For instance, if you install a 59AB sending unit on an 8BA will the oil pressure numbers increase on the gauge? Anyone know? |
01-21-2015, 10:40 AM | #8 | |
Re: Oil pressure
www.fordcollector.com |
01-21-2015, 12:27 PM | #9 |
Re: Oil pressure
What gauge is being used? If these are the readings on the dash gauge, they are almost meaningless. A good mechanical gauge is needed, the dash gauge is just a status indicator.
I was worried about my OP, about the same or less even. I put on a S-W mechanical gauge and it showed about 10 psi higher than the dash gauge. A couple years later, I came onto a certified commercial/industrial gauge with 3" dial. It showed even higher, 25 at idle and 50-ish at speed, hot, running 10w30.
'52 F-1, EAB flathead |
01-21-2015, 03:19 PM | #10 |
Re: Oil pressure
Ford does not give an oil pressure reading at idle, all that is said is in those years is 57# at 40 miles per hour, in most of all the ford v/8's ive owned the oil pressure gauge didn't hardly read at all at idle, any way oil pressure is over rated, what you want is oil flow,i had rather have 10 gallons per minute going thru the engine at lower pressure than 1 gallon at 60# per minute
01-21-2015, 06:33 PM | #11 | |
Re: Oil pressure
01-21-2015, 06:36 PM | #12 |
Re: Oil pressure
