Old 05-29-2023, 10:00 AM   #1
old31
Default Removal of rear tires from axle 1926
How are the rear rims removed from the axle on a 1926 touring? Do I need some type of puller like on an A?
old31 is offline   Reply With Quote
Old 05-29-2023, 10:26 AM   #2
stevests
stevests's Avatar
Default Re: Removal of rear tires from axle 1926
If you are referring to the "wheel", yes you should - if it just pulls off, it wasn't on tight
enough ! If you meant "rims" - 4 rim nuts hold the rim to the wheel IF you have demountables - IF wire wheels like a Model A just the wheel nuts.
stevests is offline   Reply With Quote
Old 05-30-2023, 07:35 AM   #3
old31
I am referring to removing the entire wheel/tire/wooden spokes as 1 unit, not removing the 4 nuts on the demountable.
So, I am still unclear. Does the wheel need a puller or should it just be able to be pulled off?
Old 05-30-2023, 09:21 AM   #4
redmodelt
redmodelt's Avatar
Yes, it needs a puller, but depending on if wood or wire wheels, dictates the type you need. Do a search of Ford Model T wheel puller. The wood wheel puller threads on the end of the hub using the hub cap thread.
https://www.mtfca.com/discus/message...tml?1430731837
Old 05-31-2023, 07:08 AM   #5
old31
Thanks Redmodelt
