Old 10-17-2011, 10:14 PM   #1
bergie
Default 7RT carb question
Hi, FordBarners. My project is a '50 f1. I would like to use the 7RT carb that came with the truck but the fuel inlet threads are so buggered that only a couple of threads will catch. Can I take the top off a "59" or "8BA" carb and use it without any problems other than the design of how the air cleaner is attached? Thanks for your help.
bergie is offline   Reply With Quote
Old 10-18-2011, 02:00 AM   #2
ken ct
Default Re: 7RT carb question
You can if you dont have the hi-lift nozzel bars in the 7RT.The left bar sticks up and the cover will not go all the way on.There is a little bump to accomidate the hi-lift bar on the left side of the cover. ken ct.
ken ct is offline   Reply With Quote
