Old 11-04-2019, 06:22 PM   #1
Fairview
Default Choke to start all the time?
My 1929 Sport Coupe takes a bit of choke to start even when fairly warmed up. Is that normal?
Carburetor is clean and recently rebuilt, recent ignition parts replaced, timing seems spot on, compression is strong. It just takes a quick pull on the choke, but makes it difficult to handcrank unless the engine was shut down just a minute before. Without a dab of choke it simply won’t start or fire. Position of the GAV valve doesn’t seem to help with starting. Switch to Champion W18 plugs from the original style 3X doesn’t seem to make a difference.
Any ideas for me?
Thanks
File Type: jpg 1E67D69C-FC1E-4A43-9E2E-EEB7AA1133BD.jpg (62.2 KB, 46 views)
Fairview is offline   Reply With Quote
Old 11-04-2019, 06:38 PM   #2
Curtis in MA
Default Re: Choke to start all the time?
When hand cranking use a cloths pin to hold the choke open to prime it with ignition off.
I think I always choke mine.
Curtis in MA is offline   Reply With Quote
Old 11-04-2019, 06:44 PM   #3
30 Closed Cab PU
My truck starts that way too. Do not know if it is normal.
I have a wire with a loop on the end onto teh choke plate to pull plate closed when hand starting. The wire goes up to the radiator.
Ignition off, pull closed 2 compressions with the hand crank, push the wire back in , ignition on, motor starts on next hand crank try.
30 Closed Cab PU is offline   Reply With Quote
Old 11-04-2019, 06:54 PM   #4
loubob
Sounds like it is a carb problem/issue.
loubob is offline   Reply With Quote
Old 11-04-2019, 07:00 PM   #5
Mulletwagon
Mulletwagon's Avatar
Should easily start with no choke. Might look for a vacuum leak.
Mulletwagon is offline   Reply With Quote
Old 11-04-2019, 07:01 PM   #6
mike657894
mike657894's Avatar
It should start warm no choke. 2nd on Vacuum leak.
mike657894 is offline   Reply With Quote
Old 11-04-2019, 07:02 PM   #7
Patrick L.
Patrick L.'s Avatar
Mine is old and tired and acts the same. Once warm it'll start without choke within 1/2 hour most times. More time than that and the right hand is needed. A nano-second of choke at any time is all thats needed.
Old 11-04-2019, 07:37 PM   #8
kimlinh
Check your float level. If the fuel level is low in the float bowl it is harder for the engine to draw gas from the jets.
kimlinh is offline   Reply With Quote
Old 11-04-2019, 08:10 PM   #9
aermotor
Any ideas for me?
Thanks
Go back to your previous post and research what the GAV and choke are - they are not the same animals even though they share the same knob. If you are familiar with small aircraft engines compare the GAV to the mixture control and the choke to the primer.
John
aermotor is offline   Reply With Quote
Old 11-04-2019, 08:22 PM   #10
eagle
eagle's Avatar
John
I don't think the OP is confused about the GAV vs the choke. If all else runs well, whats wrong with a short choke pull when starting? For hand starting, there is a brass wire and ring choke kit you can buy from the vendors that works well and is a great conversation starter. Also looks kind of cool.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 11-04-2019, 08:28 PM   #11
WHN
Our 29 Sport Coupe has always been that way.
Runs great, new Zenith carb, everything new or rebuilt, but needs choke to start.
WHN is offline   Reply With Quote
Old 11-04-2019, 08:54 PM   #12
Fairview
John
John,
I’m not sure what suggested to you that I don’t know the difference between the function of the choke and the GAV. This is my fourth Model A so I am right familiar with them. This one seems more stubborn than the others as far as ease of starting.
The reason I mentioned the GAV is that I figured the requirement of using the choke is showing a lean condition and the enrichment of the GAV might be helpful, but it seems to make no difference in starting.
Jeff
Old 11-04-2019, 09:13 PM   #13
Bill G
Bill G's Avatar
Mine only needs choking when cold.
Bill G is offline   Reply With Quote
Old 11-05-2019, 11:17 AM   #14
30 Closed Cab PU
I do not know if true, but have been told in the past that A's can have their own "personality". As long as; it is running well, starts easily, spark plug reads look good, decent gas mileage, does not stall at stop, settings used are not that important - no worries, drive and enjoy it.
Old 11-05-2019, 12:59 PM   #15
Patrick L.
Patrick L.'s Avatar
Yep !
