Old 08-08-2019, 10:47 AM   #1
ford31
ford31's Avatar
Default transmission oil
ever heard of mixing grease and transmission oil to get the thicker blend saw this dont think i would try it just wondered,
ford31 is offline   Reply With Quote
Old 08-08-2019, 10:53 AM   #2
Joe K
Joe K's Avatar
Default Re: transmission oil
I've heard of SAE140 oil, grease and powdered graphite. There was an article online somewhere on this - not here.
Powdered graphite is NOT a lubricant.
Sorry. Feeling hot and bothered today.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 08-08-2019, 10:53 AM   #3
Jim/GA
Jim/GA's Avatar
No. Big mistake. Don’t do it.
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 08-08-2019, 10:56 AM   #4
whirnot
whirnot's Avatar
Might be a good lubricant, but the shifting would be horrible!
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 08-08-2019, 11:31 AM   #5
Purdy Swoft
Purdy Swoft's Avatar
I agree and wouldn't try it either !!!!!!! I have used 90 weight gear oil with good shifting results . Its mostly an acquired feel .
Old 08-08-2019, 12:06 PM   #6
Bob Bidonde
Bob Bidonde's Avatar
"......mixing grease and transmission oil to get the thicker blend...."
I have read vintage articles that this is what a dishonest used car dealer would do to quiet a noisy transmission of differential.
Bob Bidonde
Old 08-08-2019, 12:22 PM   #7
duke36
Agree with Jim: Get Modern SAE 250 wt. from Resorationstuff. com or others, (Penrite, Lubriplate.) close to the original 600 wt. designed for yellow metals.
The A vendors' "600 wt." appears to be modern SAE 140 equivalent.
duke36 is offline   Reply With Quote
Old 08-08-2019, 12:34 PM   #8
Forddan
I posted a similar thread a few months ago. It was about STP. After all the suggestions I decided to use this:
https://www.restorationstuff.com/eco...oducts_id=1088
So far so good.
Forddan is offline   Reply With Quote
Old 08-08-2019, 01:08 PM   #9
Benson
Benson's Avatar
I tried 250 weight in transmission ONCE in year round daily driver ... never again.
That was more than 55 years ago.
When it got down to Zero it was very hard to shift!
At 25 below it was really bad. The shift lever would actually flex (until it warmed up) if I pushed it hard into gear.
I can not imagine what 1500 weight (if that is the real weight of the oil) would be like in the winter!
Benson is offline   Reply With Quote
Old 08-08-2019, 01:28 PM   #10
Y-Blockhead
Y-Blockhead's Avatar
I tried GL1500 from Mike's... once. https://www.mikes-afordable.com/product/GL1500.html
I live in SoCal and it doesn't get that cold here, even in the winter months. But when I took off first thing in the morning I could barely shift. It would take quite a while for the oil to warm enough to be able to shift but was still not to my liking. Went back to 600w.
Old 08-08-2019, 01:54 PM   #11
Forddan
I live in MA and I already drove it within 60 to 90 F and haven't seen any difference. But I read many comments like the previous one, so it has to be some truth for sure.
Now, just for my own curiosity, I will put a little in a container and place it in the refrigerator (not freezer as I do not drive the car in winter with the snow here) and check how it feels.
Cheers
Old 08-08-2019, 02:02 PM   #12
Werner
Werner's Avatar
Hallo Ford31,
SAE 600 easily additized machine oil is correct. No additives like Graphite, MoS2, Grease, because the main gear shaft runs off too long.
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 08-08-2019, 03:10 PM   #13
Patrick L.
Patrick L.'s Avatar
140 or 250 wgt work just fine. Its kinda hard to tell the difference. Specs for 600W fall in those ranges.
One thing, some folks swear by is STP, but, I'm one that swears at it.
Old 08-08-2019, 05:00 PM   #14
xray zulu
xray zulu's Avatar
I use Snyders 600W mixed with molybdenum disulfide powder. Smooth shift, no whine, solid lock up.
xray zulu is offline   Reply With Quote
Old 08-08-2019, 05:27 PM   #15
ryanheacox
ryanheacox's Avatar
600W from Brattons worked well when it was 10 degrees last November and it worked well last week when it was 90. I see no need to mess with what doesn’t need messing with.
ryanheacox is offline   Reply With Quote
Old 08-08-2019, 05:41 PM   #16
kimlinh
I use SAE 140 wt. gear oil and it works fine. To thick an oil can be a problem just as to thin can be.
kimlinh is offline   Reply With Quote
Old 08-08-2019, 05:55 PM   #17
rotorwrench
rotorwrench's Avatar
Soaps are blended with oil to make grease. Grease soap is not made for use in anything but grease. The other problem is that there are a lot of different soaps used in making grease. Some are compatible with mineral based oil and some are not. Gear lubes are still available for any usage an old car buff would need if you know where to find it and if you know what specification is required.
Old 08-08-2019, 11:36 PM   #18
eagle
eagle's Avatar
Lucas oil stabilizer works GREAT. Transmission is silent and smooth shifting. Great improvement over the 600w the vendors sell.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 08-08-2019, 11:47 PM   #19
Johnny Nitro
Johnny Nitro's Avatar
I used 600W, but found the viscosity would vary too widely with weather, and driving conditions for my liking. Been using Redline 80w250 since June. It’s a GLI-5 gear oil, but explicitly states it can be used in our vehicles. So far, I’ve been happy with its performance. We’ll see how thick it gets this fall in the colder weather.
Johnny Nitro is offline   Reply With Quote
Old 08-09-2019, 07:36 AM   #20
ryanheacox
ryanheacox's Avatar
Yup, GL-5 is perfectly fine in a Model A transmission as there is almost no yellow metal in it save for the reverse idler bushing and cluster thrust washers on early cases.
