Old 05-28-2019, 07:39 PM   #1
HalcyonDays
HalcyonDays's Avatar
Default Side mount arms
I am trying to remove the side mount arms from my 1931 Model A. I am attempting to do this without removing the splash apron or bracket that mounts to the frame, (riveted on with three riviets)). I have removed the large nut on the end of the arm, and have attempted to pull the arm straight out. Is this possible?
HalcyonDays is offline   Reply With Quote
Old 05-28-2019, 08:02 PM   #2
Synchro909
Synchro909's Avatar
Default Re: Side mount arms
It's on a taper and it's likely been there a long time. I'd try puttingsome penetrating oil on it, then after a while putting the nut back on till it is flush with the bottom of the thread. Then give it a "whang" from underneath while someone tries to turn it from above. A little heat (carefully) on the outer part might help.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 05-28-2019, 08:18 PM   #3
jw hash
jw hash's Avatar
if you have a pneumatic air hammer with a flat end on it hit the mounting bracket on the side it might shock it enough to get it to break loose.
jw hash is offline   Reply With Quote
Old 05-29-2019, 07:19 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
I'd try this first.
This same method works to remove pitman arms and tie rod ends on newer cars.
Old 05-29-2019, 09:56 AM   #5
Russ/40
Russ/40's Avatar
Easiest to get it to rotate first. As others said, penetrating oil soak then give it good twist.
Russ/40 is offline   Reply With Quote
