Old 02-27-2018, 07:26 PM   #1
1930artdeco
1930artdeco's Avatar
Default tube changing
I just need to confirm that I did this correctly. Had a tube that leaked somewhere-not sure where but it did leak. So I popped the outer wall off the rim, pulled the tube and replaced it with another tube. I did not add any cornstarch for lube between the tube and tire. Then I reinflated, seated the tube and popped the sidewall back on the rim. Then fully inflated the tube/tire. Still is holding air. Like I said, I just want to make sure I did this correctly.
Mike
1930 TownSedan (Briggs)
Still learning after all these years....
Old 02-27-2018, 07:37 PM   #2
160B
160B's Avatar
Default Re: tube changing
FWIW
I always run my hand around the inside of the tire to check for foreign objects or a nail in the tire that will quickly puncture the new tube.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 02-27-2018, 10:19 PM   #3
1930-Pickup
Sometimes the tube can twist or fold onto itself and you wont notice anything...except maybe a leak at the fold several years later. To prevent this, I inflate the tire and then fully deflate it, then re-inflate as normal.
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!"
1930-Pickup is offline   Reply With Quote
Old 02-28-2018, 12:00 AM   #4
RUNNERBUN
RUNNERBUN's Avatar
I do as the previous 2 posters suggested. In addition I use a liberal quantity of Talcum powder to lubricate the tube and help it settle correctly within the tire.
Adjust your points with gentle blows of a 2 pound hammer
RUNNERBUN is offline   Reply With Quote
Old 02-28-2018, 01:30 AM   #5
vern hodgson
I do as previous quote, although I inflate sans valve core, then as it releases air I bounce it around several times, reinstall the core and inflate.
vern hodgson is offline   Reply With Quote
Old 02-28-2018, 03:38 AM   #6
3.6rs
3.6rs's Avatar
Originally Posted by 160B View Post
FWIW
I used to do that also with my bare hands, until my hand came out with some sort of red liquid...
blood
3.6rs is offline   Reply With Quote
Old 02-28-2018, 08:00 AM   #7
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Once found a 1/2 X 9/16", open end wrench, rattling around in a tire!!!
Bill Amazed
"THE ASSISTANT GURU OF STUFF"
Old 02-28-2018, 08:48 AM   #8
Patrick L.
Patrick L.'s Avatar
I always install liners and make sure there are no problems with the rim and no wrinkles in the tube before inflating.
Old 02-28-2018, 09:02 AM   #9
BILL WILLIAMSON
Always remember the tube/tire skills you learned in your BICYCLING DAYS!!!
Bill Old
Old 02-28-2018, 01:10 PM   #10
1crosscut
1crosscut's Avatar
Bill Amazed
I gent that worked for me had a rear tire on a tractor repaired. Two days later it was flat again. Same guy came out to do the second repair. Opened it up and found the pliers he had been looking for.
Dave / Lincoln Nebraska
1crosscut is online now   Reply With Quote
Old 02-28-2018, 02:55 PM   #11
talwrench
I always do a soft inflate as I call it to the tube before install. Just enough air but not a stretch to the tube. This insures no wrinkles. I put one bead on than insert the soft inflated tube, wrinkle free every time. Also helps from pinching the tube when putting the second bead on.
talwrench is offline   Reply With Quote
Old 02-28-2018, 04:01 PM   #12
160B
160B's Avatar
Years ago one of our club members did a demonstration for easily mounting a tire on a rim. This method works in reverse for removing a tire from a rim.
To mount the tire:
1. Place the rim on a piece of carpet
2. Cover the rim with a black plastic garbage bag keeping the bag double thickness
3. Place the tire on the rim and work the inner bead over the rim, this can be done by hand without tools for tires that are not rock hard
4. After the inner bead is on the rim remove the plastic garbage bag
5. Place the inner tube in the tire
6. Place the plastic bag between the rim and the outer bead
7. Hand work the outer bead onto the rim, if needed you can stand on the tire and work it on to the rim.
I hope this comes across clearly
Old 02-28-2018, 07:06 PM   #13
1930artdeco
Thanks folks, looks like I did it correctly-mius the talc powder. The tube did twist and I had to untwist and then I did the 'soft' inflate to just seat it. So far there is no leaks.
Mike
Old 03-01-2018, 08:25 AM   #14
Mike Peters
Mike Peters's Avatar
To mount the tire:
160B: I like your garbage bag method of mounting/dismounting tires. Would save the wheels from paint scratches.
Mike Peters is offline   Reply With Quote
Old 03-01-2018, 09:29 AM   #15
Lona
Lona's Avatar
While running a large used car operation in the 90's, we repoed a car that had a flat tire. The shop guys repaired the leak but could not get the tire balanced no matter what they tried. They took the tire off the rim and found a shoe inside.
Interesting comments above on putting tubes in tires as that job is on my agenda today for a side mount spare that's been flat for some time.
Glen
'31 Model A Deluxe Roadster
'31 Chrysler Model 70 Sedan
'88 Pontiac Fiero GT
'36 Auburn Boattail Speedster replica
Lona is offline   Reply With Quote
Old 03-01-2018, 03:24 PM   #16
JohnTee
I've heard of putting a boot in a tire, but not a shoe .
JohnTee is offline   Reply With Quote
Old 03-01-2018, 07:03 PM   #17
BILL WILLIAMSON
NOT for cars, but because of Puncture Vines, on bicycles, we'd put a worn tire on, & stretch a GOOD tire over it. REALLY hard to do! We'd remove the valve core & carefully pour in canned milk, for an ANTI-LEAK! Smelled like CRAP, when you let a little air out!!!!
Bill Didn'tbreathe
Thread Tools
Display Modes
