Old 04-10-2019, 06:05 PM   #1
1930deluxe
Default Water pump
What is the biggest cause for water pumps to crack?
https://imgur.com/tjfllV4
1930deluxe is offline   Reply With Quote
Old 04-10-2019, 06:46 PM   #2
kimlinh
Default Re: Water pump
I don't know what the biggest cause is but if your pump casting cracked while the engine was running I'd check the fan out. It may be way out of balance and ready to fail.
kimlinh is offline   Reply With Quote
Old 04-10-2019, 06:50 PM   #3
updraught
updraught's Avatar
Bush is too big.
updraught is offline   Reply With Quote
Old 04-11-2019, 10:53 PM   #4
Mike V. Florida
Mike V. Florida's Avatar
Original fan shedding a blade.
Old 04-11-2019, 11:59 PM   #5
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Removing or installing a bushing wrong. Where’s the crack?
Old 04-12-2019, 07:34 PM   #6
1930deluxe
The best I can find out is there were several companies manufacturing the water pumps for Ford and the tolerances were not the same. The crack is at the rear bearing housing and goes to the upper mounting hole. I always have a problem down loading photo from my pictures.
Old 04-12-2019, 07:37 PM   #7
1930deluxe
Engine has not been running yet
