10-01-2011, 07:54 PM | #1 |
Tudor body in two pieces
I am working on a 30 sedan body. It is in two pieces, split between the doors. The cowl is from a coupe. What is going to be the best way to put this body back together.
10-01-2011, 08:04 PM | #2 |
Re: Tudor body in two pieces
If you are building a hot rod the cowl will work but, if you are going back original the coupe cowl is not going to work. The a pillars are too short by about 1" to work as a tudor part.
10-01-2011, 08:06 PM | #3 |
So the roof is 1" lower on the coupe than a sedan.
10-02-2011, 06:34 AM | #4 |
Actually the roof is the same height but the A pillars are designed differently. When you put it all together and the wood is in you will find you have a 1"X1" square at the top of the pillar that the wood shows and the top or gutters won,t cover this area.
You need to look at a Tudor cowl to see what I mean, the difference will be obvious in comparison. I may be able to get some pics unless Brent has some he will share. |
10-02-2011, 07:14 PM | #5 |
I hung my sedan doors on that cowl. the doors do sit higher at the top. My buddy has a sedan that I will have to compare with. Anybody else have any thoughts.
10-08-2011, 07:20 PM | #6 |
10-08-2011, 09:30 PM | #7 |
Different cars.
