Old 09-22-2020, 01:51 PM   #1
Dusty12682
Dusty12682's Avatar
Default T front spring
I need some help getting a front spring for the T. I would prefer something cheap, does anyone know of a front leaf spring that will fit the T that won't break the bank?
Sent from my SM-N960U using Tapatalk
Dusty12682 is offline   Reply With Quote
Old 09-22-2020, 02:28 PM   #2
J Franklin
J Franklin's Avatar
Default Re: T front spring
Keep an eye on eBay. New are really only a few hundred dollars and will last longer than you.
Old 09-22-2020, 02:38 PM   #3
Dusty12682
Dusty12682's Avatar
The ones I see are much more expensive, and as I am building a speedster, so I'm going low.
Old 09-22-2020, 03:08 PM   #4
J Franklin
J Franklin's Avatar
Try Snyder's Ford parts. I see one listed for about $250.
Old 09-22-2020, 03:16 PM   #5
Dusty12682
Dusty12682's Avatar
I'll look there, most of the ones I see are 300 and up. Thanks! By the way... What is the spring from eye to eye for a 18 to 25 front axle?
Old 09-22-2020, 07:16 PM   #6
39portlander
39portlander's Avatar
Not sure were you are located Mr. Dusty but I got my springs from a fella in W Hartford Conn who builds a very nice model T front and rear spring. www.t-springs.com
There are some reasons I would avoid fleabay for leaf spring, there on there for a reason CRAP. I would check MTFCA or your local craigslist, I do see in large parts sell offs.
Again where your building a speedster and have measurement questions I would contact "T" springs and could probably build you a proper spring for your application. Good luck and let us know how you make out.
39portlander is offline   Reply With Quote
Old 09-22-2020, 07:24 PM   #7
Dusty12682
Dusty12682's Avatar
Originally Posted by 39portlander View Post
Not sure were you are located Mr. Dusty but I got my springs from a fella in W Hartford Conn who builds a very nice model T font and rear spring. www.t-springs.com
Again were your building a speedster and have measurement questions I would contact "T" springs and could probably build you a proper spring for your application. Good luck and let us know how you make out.
Cool! Thanks! I am very happy to accept all advice, and this is awesome! Luckily I'm only in need of a front, the rear is 4 quarter elliptical springs. Here is my build: https://r.tapatalk.com/shareLink/top...ink_source=app
