Old 11-16-2020, 05:16 PM   #1
old31
Default 35 condenser
This is the condenser I took out of my 35 Roadster.
Does anyone know what the NAPA part number is? I would like to pick one up tomorrow.
Old 11-16-2020, 05:35 PM   #2
35fordtn
35fordtn's Avatar
Default Re: 35 condenser
You must have a remote coil adapter plate. If you chose Napa go with a FA54. We sell the FA54 for $8.59. It will look different than the one you are currently using but is ideal for the Early Ford dual point distributors
35fordtn is offline   Reply With Quote
Old 11-16-2020, 05:48 PM   #3
Lawrie
Lawrie's Avatar
You can use a condenser like that one when using a rewound original coil, I use them on my fords.
What you do is put a 3/16 did screw in through the hole where the original condenser was , use a spacer and a lug for a spade type connection, then put a spade type end on the condenser wire , and mount the condenser onto a little mount onto the top bolt on the timing cover, then its a nice looking installation, AND if you have to change one on the road its an easy job.
Lawrie
Lawrie is offline   Reply With Quote
