11-06-2020, 10:33 AM | #1 |
1936 fuel pump thread size
There are two style fuel pumps for 1936.
One was all metal and the second one had a glass bowl. I have the glass bowl style and was wondering if anybody new that thread size. I think it’s 1/2 20 thread. I need fittings for my gas line and need the size to order. Thanks, Blast. Last edited by Blastfromthepast; 11-06-2020 at 01:38 PM. |
11-06-2020, 08:56 PM | #2 |
Re: 1936 fuel pump thread size
The glass bowl pump did not come out until 1947. Regardless both use 1/2-20 threads with a special fitting and a ferrule. We sell the fittings w/ ferrule for $1.49 each if you can’t find elsewhere
11-07-2020, 12:15 AM | #3 |
Blast, Here are some images showing the correct fittings, hose and fuel line for your 36 Ford. The steel fuel line comes from the gas tank thru the frame and terminates on the firewall and held in place by bracket 18-9296. There is then a flexible fuel line from there to the intake side of the fuel pump. The outlet side of the fuel pump has a steel fuel line with special fitings and it runs to the carb.
11-08-2020, 11:50 AM | #4 |
