11-02-2020, 09:29 AM | #1 |
Mercury rebuilt EAC longblock-whats it worth?
Have a friend who came into this Mercury EAC longblock over the weekend. Apparently the guy who he got it from is liquidating a lifetime of parts. From what I understand, it is a Ford reman. It has been stored well/dry. Not locked up. Any idea on value? Thank you.
11-02-2020, 10:20 AM | #2 |
Re: Mercury rebuilt EAC longblock-whats it worth?
Pressed him for a few more details. The tag says it is 40 over on the bore and 20/20 on the crank. Also not a Ford reman, it is a National something or other out of Atlanta, GA. He does not know how old it is. Does turn. Has a new oil pump with it, but no front cover or oil pan.
11-02-2020, 10:28 AM | #3 |
Good question: If a genuine Ford reman. it wouldn't be done if not a good core. So the
reman was back in the day likely from the 1960s or early 70s. Now and here a good block thermo cleaned , re bore, crank, polish or a grind, all valves seals gaskets oil pump comes to around $1100 and thats our wholesale parts price. no water pumps or distributor. Labor I'm retired so 20 25 bucks gives me something to do that I like to do. So my price around $1500 because I don't charge list price on parts just shipping. So now you have my garentee and none with your friends engine. So, If I put todays labor shop time you will be up to around high 2 to 3000 $ for a new fresh engine, but a fresh 50 yr old or older fresh engine never fired still will need seals gaskets from age. He could get bucks if he finished it then on a test stand Here it , & hear it run . Then sold............sam |
11-02-2020, 10:51 AM | #4 |
I agree about getting it running. Engines like this seem to be coming out of the storage lately. It's so hard to say it's worth. To do one right, you are looking at $4-$5K for stock and a lot more if hi-po.
Yet, a motor like this would bring around $1K as it sits. Without it running, it really is a pig in a poke and the buyer is taking a chance that it could be no good. |
11-02-2020, 11:50 AM | #5 |
I would measure the stroke to verify it has a Merc crank in it which would make it more desirable.
11-02-2020, 12:10 PM | #6 |
Easy way to see if it is a mercury crank is to see if it has the 5/8" or 3/8" clean out plugs in the crank. The larger is "typically" mercury. |
11-03-2020, 07:14 AM | #7 |
The condition of the block, will determine the price. pressure test it.
11-03-2020, 10:23 AM | #8 |
Assembled 8BA blocks can be pressure tested; I made this gizmo to do just that. I have done it successfully on 3 blocks. You either use the black cap to cap the water pump outlets if the pump is on the car or the larger plate to block them if the have been removed (or if they leak). The smaller plate with the gauge is put on the thermostat housing mount on the head and a small amount of air pressure is induced using the schrader valve.
It may not tell you a block is definitely good, but it will cull the bad leakers. Good water pump seals will usually hold the 5-10 lbs pressure I usually use; if they won't, they need to be replaced anyway. |
11-03-2020, 12:03 PM | #9 |
I am primarily interested in testing bare blocks. I probably have 12 or so junk waterpumps here. Could I just remove the shafts and make a gasket from epdm rubber roofing and bolt them on? Will the same type pump work for 8ba and the 59a style?. In the same vein, a cyl head with an epdm gasket having only the bolt holes? Hope this isn't a hijack. Always looking for shade tree solutions, and speedway doesn't even offer the kit anymore.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
11-03-2020, 12:50 PM | #10 |
Gary.....you would have to seal the head bolt or nut with some type of rubber washer under a steel washer. Same with the pumps. Any where air can leak (unless you find a crack) has to be air tight to have an accurate test...... how are things under that shade tree??......Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
11-03-2020, 01:22 PM | #11 | |
Thread Tools | |
Display Modes | |
